Question: Globalsat BU-353 Mouse GPS
Does this unit take the place of a gps . I have a Garmin 60 hand held - no map capacity - I have map source & base camp loaded on a laptop as well as Garmin's Topo Australia & NZ v3 maps registered on a DVD & shonky maps . Can I replace the gps with the BU-353, Is this all compatible ?
Reply By: Life Member - esarby (NSW) - Sunday, Apr 15, 2012 at 13:03
Nick b. The BU-353 is the satellite receiver for what you plug it into. It receives the GPS signal for the receiver. Mine is connected to my laptop.
AnswerID: 483178
Reply By: Member - Craig F (WA) - Sunday, Apr 15, 2012 at 14:25
Short answer Nick is you need,
Laptop/GPS unit > GPS reciever > appropriate Application to process the data > Maps.
Investigate your local GPS - mapping supplyer and have a talk to them show them what you have and they can inform you of your options. Then you can move foward.
Craig
AnswerID: 483182
Follow Up By: Member - nick b - Monday, Apr 16, 2012 at 07:09
Thanks for the reply's
"Can I replace the gps with the BU-353, Is this all compatible ?" NO not compatible
FollowupID: 758493
Reply By: ExplorOz - David & Michelle - Monday, Apr 16, 2012 at 10:35
Nick,
Yes you can replace the Garmin with the BU-353 but I am not sure if the map source with operate with a BU353 I believe it needs to talk to a Garmin device but I am not really sure. I used to have MapSource but that was a long time ago.
David
AnswerID: 483265
Follow Up By: Member - nick b - Monday, Apr 16, 2012 at 20:49
Thanks David : What i under stand is that it wont work on mapsource but it will work with Nroute & others .....was thinking it would give better reception than gps in vehicle
Also thanks for reply to EOTrackme ... don't have a spot .
cheers nick
FollowupID: 758563
