Monday, Apr 30, 2012 at 13:57
Mudguard - A good guide is 4 litres per person per day for drinking, you can get away with the same for washing if you're extremely careful.
We only had belt mounted
water bottles for washing AND drinking in the Jungles of Noggieland!
My old Sgt was pretty good at describing the ABC's of washing with a
water bottle! ( [under]Arm, Bum and Crotch!) [:-)
It sounds to me as if you have adequate supply in the amounts you mentioned.
If you find some surplus clean rainwater puddles, or other supply such as a good
well, you can lash out on a bush shower.
This could be described as "discretionary"
water use.
Be aware that clean, pure
drinking water is the main priority. Often, with a
well, the
water may be contaminated, so boiling or filtration is important.
I've known people pulling
water from a
well on dusk - using it for drinking and cooking - then finding a carcass floating in the
well in broad daylight! [:-)
It's not the first time, either, that I've I employed a clean rainwater puddle, pumped through the Glind HWS to get a good quick hot shower!
Cheers - Ron.
484630
