F250 2002 7.3 auto diesel will not engage park
Submitted: Saturday, May 26, 2012 at 16:39
Member - Margaret B (NSW)
Here we are in Mt Isa on our way to the west coast and have encountered a problem with our tow vehicle.
The truck will not engage
park and the key wont come out.
Can anyone offer any advice please
Thanks Margaret
Reply By: blown4by - Saturday, May 26, 2012 at 17:32
Might not apply to the Effie but on some vehicles you have to have your foot on the brake pedal to engage
Park and to release the lever from
Park. If you have been off-road could be a stick or rock or mud jamming up the linkage or a bent linkage underneath. Failing that the linkage could be loose or slipped on the shaft that goes in to the transmission. Without stating the obvious, make sure the
park brake is applied and the
wheels are chocked to prevent any movement in either direction.
486823
Follow Up By: Phillipn - Saturday, May 26, 2012 at 18:55
My neighbour had the same problem last week, it was a stone caught under the linkage. Would not go into
park.
Try looking their ,it may save a few $$$$$$s.
762051
Follow Up By: Phillipn - Saturday, May 26, 2012 at 18:56
park.
762052
Follow Up By: Phillipn - Saturday, May 26, 2012 at 18:58
Ha had a stuff up, hit the submit twice.
762053
Follow Up By: Member - Margaret B (NSW) - Saturday, May 26, 2012 at 21:34
Have checked that, this model changes gears with a cable, all clear in that department
762069
Reply By: sue and shaun - Saturday, May 26, 2012 at 18:57
hi margaret b just had a quick look in manual possibility it could be fuse but i struggle with that one . i can contact my auto mechanic on monday morning if you are still stuck hopefully blown 4by advice has got you out of trouble he pretty much covered every thing . If you need any help dont hesitate to contact me if i can help i will cheers
486835
Follow Up By: Member - Margaret B (NSW) - Saturday, May 26, 2012 at 21:38
have checked the fuses, was hoping for a blown fuse, but not to be
Thank you
762070
Reply By: BV - Saturday, May 26, 2012 at 19:24
Margaret,
How is the oil level in the gear box?? Having had a 250 in the past I encountered difficulties with the transmission shifting due to low oil.
Bruce
486839
Follow Up By: Member - Margaret B (NSW) - Saturday, May 26, 2012 at 21:40
Tranny oil level is ok, thanks, will have to wait til Monday for garage to open
762073
Reply By: Shaker - Saturday, May 26, 2012 at 19:46
If you can't fix it, you are lucky there is a Ford dealer in
Mount Isa.
486840
Follow Up By: Member - Margaret B (NSW) - Saturday, May 26, 2012 at 21:41
Thanks for the info, have located the dealership, will be there at opening time on Monday
762074
Reply By: Rockape - Saturday, May 26, 2012 at 20:21
Margaret,
have a look in your owners manual. Some vehicles have a hidden button near the shift lever that you can access to get it in and out of
park.
486845
Follow Up By: Member - Margaret B (NSW) - Saturday, May 26, 2012 at 21:44
Thanks, will do that now
762075
Reply By: Motherhen - Saturday, May 26, 2012 at 23:19
Just guessing here Margaret, but could your batteries be getting low? To my way of thinking you cannot remove the key only because the vehicle is not in
park - so that is the prime problem. Good luck with getting it resolved.
486860
Follow Up By: Member - Margaret B (NSW) - Sunday, May 27, 2012 at 20:15
batteries OK, thanks, now investigating the cable
Marg
762173
Reply By: Ron N - Saturday, May 26, 2012 at 23:25
Margaret - The Just Answers website is reasonably good at providing answers to tricky problems with American vehicles. There's usually a number of qualified Ford technicians online at any time, prepared to assist.
http://www.justanswer.com/ford/6k3fx-ford-f250-pickup-4x4-1996-f250-powerstroke-wont.html
I presume you haven't parked in a position where's there's a heavy load on the
parking pawl (loaded and on a slope), or that you haven't parked with steering load on the ignition locking mechanism?
Both of these situations will prevent the
park brake pawl from disengaging, and the key from being removed.
Cheers - Ron.
486861
Follow Up By: Ron N - Saturday, May 26, 2012 at 23:28
Oops, my bad, I misread your post. I thought you stated it wouldn't disengage
park.
Yes, the key in modern vehicles won't come out until you apply the
park brake. So the problem created by the
park brake not engaging will prevent the key from being removed.
Cheers - Ron.
762080
Reply By: Geoff in SA - Sunday, May 27, 2012 at 09:07
hi marg
I too have an effy and like yrs is cable to the transmission.
there is an interlock between
park and the key removal solinoid.
it is just possible the may be an adjustment from stopping it going into the
park position.
will it go into
park while moving forward or back at very low speed?
maybe you could try rockingr it a little.
or maybe try manually operating the linkage on the side of the gerbox.
BTW
nice rig
But what are you carrying?
looks very back end heavy.
have you thought of getting some airbags fitted to help the poor old rear springs?
I will follow and see what the effy dealer has to say
Geoff
486871
Follow Up By: Member - Margaret B (NSW) - Sunday, May 27, 2012 at 20:20
Thanks for your info, tried your advice, still will not budge.
The photo of the rig was taken on a slope and makes it look very back end heavy, have airbags already installed.
Thanks again for your info
Marg
762174
Reply By: Member - mechpete - Sunday, May 27, 2012 at 12:01
hi Margret
dissconect the shift cable both ends an check the cable isn,t binding .
park is a mechanical lock in the box
mechpete
486888
Reply By: Member - Margaret B (NSW) - Monday, May 28, 2012 at 16:44
Problem sorted. It was a small piece of tarred stone stuck right up under the cable at the transmission, it was out of sight, had to pull cable off before it could be located.
A very big thank you must go to the
Mount Isa Ford dealership for their prompt and courteous attention which incurred no cost.
Thank you to all , we will be on our way to
Camooweal tomorrow.
Margaret B
487006
