Thursday, Aug 02, 2012 at 09:55
Hi Ferreting,
I have had the exact same electrical drain on my
Ranger ever since new, in the 7 months that I have owned it I would have had to jump start it about 6 times after leaving parked for as little as 1 day, I had the battery replaced under warranty when it was 1 month old believing it must have been faulty, it is a royal pain in the butt to have a new vehicle that lets you down so often (I do always carry jumper leads just in case) today will be another trip to the dealer to complain about the electrical discharge problem. did you get your electrical problem solved?
Apart from that I do love the
Ranger,
mine is a manual super cab, style side ute that I tow a 28 foot gooseneck/5h wheeler trailer with it as
well as other trailers and equipment. it tows with ease, plenty of power and very good
fuel economy for the size of the vehicle (approx 9l/100) but not quite as good on
fuel as my previous pk
ranger (8.2l/100)
The ride quality is pretty good and it does feel good on the road but with the different and softer
suspension to the previous model I doesn't corner quite as hard/fast.
The 6 speed manual has the ratios a little close for normal unladen driving but it is superb for heavy towing and the lower ratio 1st and reverse gears are way ahead of the previous model and so much better than the nissans
I found that the standard exterior convex mirrors to be a complete waste of time and very hazardous when trying to back long trailers in tight areas so I replaced the mirror lenses with flat mirrors and it makes it so much easier and safer.
As for power the
Ranger is top of its class, it will idle off in 3rd gear (a friend told me it would so I had to try it)
If I can get the electrics sorted out on this vehicle I will be be a very happy chappy.
The Coyote
767709
