water pump filter and installation
Submitted: Sunday, Sep 02, 2012 at 08:49
ThreadID: 97790 Views:3317 Replies:2 FollowUps:4
Hi I have purchased a propump Fl-2202A 12 v inline pressure sensitive pump on ebay and it didn't come with any instructions etc and just wondering if someone could give me a guide on the installation and also a tip on what type of grit filter you would recommend.....it is for use in my shack with solar system so will be pumping rain water from tank
cheers Rich
Reply By: Member - Ann D (WA) - Sunday, Sep 02, 2012 at 11:56
rfaza,
have a look on myswag.org.many have plumbed pumps into their campers,it should give you an idea as to how.
Ann D
AnswerID: 494114
Follow Up By: rfaza - Monday, Sep 03, 2012 at 09:57
thanks Ann have just registered!
FollowupID: 769794
Reply By: Flighty ( WA ) - Monday, Sep 03, 2012 at 09:24
Rich.
Have 1 of these units in my cruiser and also 1 in the camper, work well but haven't bothered with a filter as such.
Only thing to remember is to fit food grade hose and reinforced hose on the delivery side as they have a pretty good pressure rating 80 PSI I think.
Paul
AnswerID: 494157
Follow Up By: rfaza - Monday, Sep 03, 2012 at 09:56
thanks for that Paul, will take your advice re hoses!....one question the pump has no marking for inlet and outlet.... can you give me a heads up on your unit connections
cheers Rich
FollowupID: 769793
Follow Up By: Flighty ( WA ) - Monday, Sep 03, 2012 at 10:27
Rich
Hold pump with label to you and connections at bottom.
delivery /outlet is the Left hand one.
Paul
FollowupID: 769796
Follow Up By: rfaza - Monday, Sep 03, 2012 at 17:28
too easy! thanks very much
cheers Paul
FollowupID: 769809
