Water Crossing in 80 Series Landcruiser
Submitted: Thursday, Apr 18, 2002 at 00:00
Gordon
My wife and I are heading for the Kimberlies solo in June in my 80 Series turbo diesel and want to be prepared for possible deep
water crossings. I have fitted a
snorkel and will be taking a radiator blind. We have an electric winch and recovery gear just in case the worst should happen. I know to check
water depths/ obstacles, wind down windows and have a winching plan. But I have heard that it is also advisable to slacken the radiator belts and either plug or fit breather extensions to clutch housing, diff housing and timing cover. I have 2 Questions: 1)For anyone who's been to the Kimberlies at that time, can you advise likelihood of deep
water on either the
Gibb River Road or the Kalumbaroo Road? 2)For others who have done deep
water crossings, how do you prepare your vehicle prior to taking the plunge?
Reply By: Tom - Thursday, Apr 18, 2002 at 00:00
Gordon - my wife and I drove through the Kimberlys' in July August 2001 with a Landrover and offroad campervan. We had several
water crossings but nothing deep - deepest was
Pentecost River but only a bit over axle depth. I guess it all depends on conditions at the time - cyclones etc, but you certainly sound
well prepared. The Gibb R road was the roughest I have ever encountered, but hadn't been graded for a while. You will enjoy the area.
2930
Reply By: Goran - Thursday, Apr 18, 2002 at 00:00
Gordon,if you fit the radiator blind properly you dont have to slacken the fan belt,providing you dont stall anywhere.Same for timting cover.Diff and gearbox breather lines have to be extended.It pays and it is an easy job.Cluch housing should be ok againg providing you pick the right gear before crossing..(2 or 3 rd low sounds good)and avoid using it under
water during the crossing. the best thing you can do is cool your running gear prior to crossing as hot seals will let the
water in casings regardless of breaders.
2936
Follow Up By: Gordon - Friday, Apr 19, 2002 at 00:00
Goran, thanks for your reply.Can you give me more detail on what is involved in extending diff and gearbox breather lines. 1)What materials are needed to rig up the extensions? 2)Are any special
tools required? 3)Are the extensions permanent or temporary? 4)Where to extend them to 5)Any special knowledge required?
1143
Reply By: Clay Golledge - Friday, Apr 19, 2002 at 00:00
I have done the
Kalumburu road several times, it is likely to be more of a problem than the GRR. If the road is open, and it should be by June then there are unlikely to be any problems for an 80 series with a
snorkel. The last 70 odd k's from Theda to
Kalumburu can be pretty rough depending on where the Grader is and what has been done. It's a good idea to overnight at Theda and do the trip to
Kalumburu slowly the next day with a couple of good scenic river crossings for stops and maybe a bit of fishing. Make sure you go out to
Honeymoon beach and catch up with Les..it's quite an experience!
2945
Reply By: Steve - Friday, Apr 19, 2002 at 00:00
Best place to extend them to is under the bonnet up as high as you can get it. I used 3/8 inch pressure air tubing. Take off your existing breathers on your front and rear diff. The 3/6th tubing should push over the nipple on your diff. Use stainlesss hose clamps at every join. I ran my rear line inside the chassis rail up to the front. I picked up a line from my gearbox and transfer case with a nylon tee piece (make sure you get ones that don't mind oil). I then put another tee in to pick up the front diff line. I finished the end of the tube with a Ryco
fuel filter, which keeps gunk out of the line as
well as caturing any drops that might sneak in. The line is as high as it will go on the firewall. The gearbox and transfer case breathers on an 80 generalling are combined into one rubber hose that end just on top of the bell housing at the back of the motor. Take the flapper valve off and stick a joiner and hose on to extend into you combined line. Hope this helps
2948
Reply By: Goran - Friday, Apr 19, 2002 at 00:00
Steve has said it
Gordon.That is how is done.
I run my rear diff breader up against the
fuel filler which is as high as the firewall.
2955
Reply By: bob - Monday, Apr 22, 2002 at 00:00
Gordon
Crossing the GRR is not to bad if the river crossings are to deep the road will be closed anyway.That was our experience in may 01 we could only travel about half way along but
well worth it
2995
Reply By: Michelle - ExplorOz - Thursday, Apr 25, 2002 at 00:00
Gordon - you are unlikely to encounter any
water crossing on the GRR that will cause you a problem during June (refer to current road condition reports to see how it is now). However, you never can tell with the
Kalumburu Rd, especially towards the top. In this case, the advice you have received here is all accurate. Extending diff breathers should be the first mod you ever make to your vehicle anyway. Do that even before buying the
snorkel! It's fairly easy and costs next to nothing to do.
3095
