Engel Combo (dual zone) Fridge/ freezers
I'm considering purchasing one of these units, either the 57 or 75 litre. The fridge is cooled with a thermostatically controlled fan from the freezer section. Does anyone have experience or advice concerning these units. Waeco also manufacture similar models but I have been advised against these units.
Jock
Reply By: Mick O - Wednesday, Nov 14, 2012 at 09:27
Yes I have been using the 75 Litre for the past three years and have been very happy with the way the fridge has performed. I wrote up a review of it here;
ENGLE COMBO & PLATINUM DROPSLIDE
Cheers Mick
AnswerID: 498477
Follow Up By: Mark T6 - Wednesday, Nov 14, 2012 at 12:06
I have used the Waeco version for 3 years and LOVE it.....I imagine Engel had to intorduce one as so many Waeco's were being sold.
I imagine it's a bit like Tyres, I run BFG's but everyone that run Coopers, or Mickey Thompson says they are better...to each their own I reckon.
We freeze our meat into little one meal packs and stick it in the freezer section and run the rest as a fridge...works like a charm and has done for 3 years!!
FollowupID: 774477
Reply By: harry & the hobbit - Wednesday, Nov 14, 2012 at 12:22
Hi Jock,
We have also had the larger Engel for 3 years and it has been faultless. A recent trip to the Cape we carried 30 cryovaced meals for the 2 of us in the freezer section. The only drawback with the unit is that it takes up a lot of room in the back of the 'cruiser.
Regards, Robert
AnswerID: 498495
Reply By: Simon C - Wednesday, Nov 14, 2012 at 12:52
I have had a 60 litre unit (not the combo) for around 4 years, and then got a 40 litre fridge/freezer as well. The reason for buying the 40 litre is that the 60litre is so big, and takes a lot of room. Knowing what I know now.....I would have purchased 2 x 40 litre units, and then had a dedicated Fridge and Freezer as required. Some times....I only need either one. Check how much room the 57 litre(same as 60 litre) unit tanks up in the back of your car. Just my 2 cents worth.
AnswerID: 498500
Follow Up By: Member - Noldi (WA) - Wednesday, Nov 14, 2012 at 18:29
I have a similar set up, figured if one goes wheels up I can squeeze into the other.
Had the Waeco 6 years and the engel 12 months no problem with either.
FollowupID: 774494
Reply By: Member - John (Vic) - Wednesday, Nov 14, 2012 at 14:13
Great unit!!
There is one for sale in the classified section of this site.
AnswerID: 498508
Reply By: Millsy999 - Wednesday, Nov 14, 2012 at 18:41
Another unit that may be worth considering is the new Primus Mammoth range. I believe Evakool are also selling the exact same units under their own branding. I have just purchased this one.....
http://www.primusaustralia.com.au/index.php?p=line&sid=1341895712
They are now running a Secop compressor (formally known as Danfoss) and with physically seperate fridge and freezer zones it is a pretty practical setup. You can run it as fridge/fridge, fridge/freezer or freezer/freezer.
I have only been running mine as a beer fridge and a freezer at home on 240v, no chance to take it on a trip yet or do any current draw analysis, but its temperature control seems to be pretty good. Its doing an admirable job of cooling beer :) Seems to be pretty sturdy in its construction as well. Metal body with steel latches and handles. I picked mine up from Anaconda for $1230 with a bonus bag, and the Primus unit comes standard with the 240v adaptor, whereas I think its an extra with the Evakool.
Shane
AnswerID: 498530
Reply By: Bush Wanderer - Wednesday, Nov 14, 2012 at 20:05
After talking to the Waeco rep at the Perth 4wd show, I won't be going Waeco again. I have an 18 year old Waeco with a danfos bdf50 and has been perfect. Still going strong. The new CFX range no longer use the Danfos compressor as the compressors are now made on china. Waeco dont yet have a solution for the larger square box compressor fridges (80 and 110 litre models) that now use the Chinese made Danfos. The new genuine Waeco compressor according to the rep does not perform anywhere near as well as the Danfos compressors.
Engel next time for me, as I don't want to rely on Chinese compressors when I am on the csr or gunbarrel.
BW....
AnswerID: 498537
Reply By: Bazooka - Wednesday, Nov 14, 2012 at 20:56
One man's fridge research
An interesting read with some observations regarding the efficiency and cooling ability of Danfoss V Sawafuji (Danfoss superior).
AnswerID: 498540
Reply By: gbc - Wednesday, Nov 14, 2012 at 21:47
I had the combi 60 for a while. It has a massive 'footprint' in a car. It worked perfectly well, kept everything cold, but was a complete pain to clean out and generally look after. God forbid you spilled anything.
I've had an evakool RF60 for the past 7 years - It gets turned off every now and then for a defrost, otherwise it hasn't been turned off. Not as 'flash' as some, but definitely up to the task, and more practical to look after and keep clean. Much smaller footprint for the same storage space, but a little bit taller which may not suit?
AnswerID: 498545
Reply By: Joker - Wednesday, Nov 14, 2012 at 22:28
Thanks for all your info. I read the comparison on the compressors and now note that Waeco no longer use the danfross compressor on the new CFX range as has been stated. I think I may opt for 2 engels for ease of movement, ability to use only one if needed and of course reliability.
Thanks Again
Jock
AnswerID: 498547
Follow Up By: Dennis Ellery - Wednesday, Nov 14, 2012 at 23:20
Wise choice Jock – I have a 40 litre Engel and a Waeco cf40.
Run side by side for years - if the voltage gets low or the temperature gets high or the air supply is restricted in the back of the 4WD the Waeco packs it in first, whilst the Engel soldiers on.
FollowupID: 774516
Reply By: coonick - Thursday, Nov 15, 2012 at 10:10
I wouldnt say that the danfoss is superior to sawafuji at all.
In reality the more simple design of the latter would be held
in more higher regards.
The review is interesting reading.
AnswerID: 498560
Follow Up By: Bazooka - Thursday, Nov 15, 2012 at 11:59
As far as efficiency and cooling ability goes, for the size he was looking at, the evidence (he saw) seems to come down clearly on the Danfoss side Coonick. Reliability and longevity - who knows?
Many years ago, not long after Waeco first appeared in Oz, one of the 4WD mags did a pretty comprehensive controlled and measured fridge test (in a temperature regulated shed iirc). I only occasionally read the mags these days but I haven't heard of any decent test since unfortunately. Anyone got a link to something worthwhile? I'm happy with my old Waeco but always interested in ideas for future needs etc.
FollowupID: 774539
Follow Up By: Bazooka - Thursday, Nov 15, 2012 at 12:22
More interesting reading.
Unfortunately no 'real life' test with a mix of uncooled, pre-cooled, and frozen contents.
FollowupID: 774545
Reply By: Dion - Thursday, Nov 15, 2012 at 10:26
I brought the 57L (60L) Engel last year for a trip to Alice Springs following as much as I could the old Central Australian Railway.
All the victuals were only brought on the day of the departure which means meat wasn't initially frozen. The only two frozen products in the freezer part of the Engel were a 2L container of Golden North ice cream and a precooked stew also in a 2L ice cream container.
Use of the Engel (same as in the other vehicle except it was a 32L running as fridge only) was to turn on as part of pre departure checks in morning, run all through day and then switch off in the evening. It took about four days into the trip before meat in the freezer section had frozen.
As hindsight is a wonderful thing, meat to be frozen should have been purchased a few days beforehand and frozen. What prevented us from doing that was the other participants in the trip were in Adelaide some 350km's away and we only got together to purchase the victuals on the morning prior to departure.
Also to note as this 57L was only picked up one week prior to departing, I hadn't secured it down in the back of the Rodeo, so it bounced around a bit which didn't seem to effect the operation of it, but did a little external sheet metal work damage around the base. This was caused by that lack of restraining and the ripples in the base of the Rodeo tub, so my fault. On a flatter surface I don't expect this would have occured. I've straightened it out and applied a few more pop rivets around the base.
In addition to the 32L and the 57L in the back of each of the utes, each ute also was running a 15L Engel in the cab.
I clearly can't speak of the other brands of similar fridges, however I am happy with what I've got, and heeded the lessons from the first experience. Whilst it took four days to freeze some of the fresh meat, (yes it should have been frozen first), I'd also expect that if I didn't switch fridge off at night, that four days would have been lessened.
Dion.
AnswerID: 498562
Reply By: Berniec - Thursday, Nov 15, 2012 at 20:40
I recently purchased two Engel Eclipse 40 litre units. The main reason is that they were $799 RRP (and I got them slightly cheaper) each while a 60 litre Engel was more than double that. The Eclipse has a tough plastic outer case but are identical to the 40 litre steel unit internally. I put the basket from the steel unit in the plastic one. So now I have one unit for a fridge and another for a freezer. Takes up a bigger total footprint but very practical. This may be worth considering.
Happy touring!
AnswerID: 498589
Reply By: rumpig - Friday, Nov 16, 2012 at 21:15
i own the 75ltr Engel and have done since 2006, it's seen a bucket load of Oz and been across countless klms of corrogations without a problem. now in saying that, it's a power hungry beast, and if i had my time again i'm not sure i'd buy another, maybe consider 2 X 40ltrs instead if you have the room, use one as a fridge and one as a freezer. there is nothing wrong the unit i own other then the power it consumes, if you buy one with this in mind then you'll be happy with your purchase, don't realize the power it uses when the dial is cranked up to get the freezer doing what it's supposed to do, and you'll be disappointed with your purchase IMHO.
i've owned a 40 ltr Engel also and notice you don't need to crank up the setting as much to get it to freeze stuff, where as the bigger fridge needs a higher numbered setting to get it doing what you want to do.
AnswerID: 498644
Follow Up By: Joker - Saturday, Nov 17, 2012 at 04:26
rumpig, I ended up buying the Engel 50th anniversary 40ltr with the inbuilt voltage protection . I already own a small Waeco fridge that will do for the present. I will probably buy an eclipse if I need a larger unit. I came to the conclusion that the dual zone models took up to much room and would be difficult to move if need be. Thank you and everyone else for your valued opinions.
Jock
FollowupID: 774644
