2 pin low voltage plugs
Submitted: Saturday, Nov 17, 2012 at 13:27
judes34
Does anyone know where I can buy 2pin low voltage plugs (the type with 1 horizontal and 1 vertical pin) for a reasonable price? I've found the 12v
Shop where they're around $18. Can anyone suggest a better price than that?
Reply By: miandering fiander - Saturday, Nov 17, 2012 at 13:32
Try an electrical wholesaler, they have a range of plug tops.
498656
Follow Up By: Bob Y. - Qld - Saturday, Nov 17, 2012 at 14:23
Jaycar have the plugs(PP-2075) for $8.95, and 2 different sockets for $16.95 each.(PS-2073 & PS-2074)
They're called "2 Pin 32v Plugs" in the latest catalogue.
774656
Follow Up By: judes34 - Saturday, Nov 17, 2012 at 14:46
Thanks very much. Should be able to sort it from there.
774658
Reply By: Michael ( Moss Vale NSW) - Saturday, Nov 17, 2012 at 14:04
I had that plug type on my fridge from new but recently changed to 50amp Anderson plugs and much cheaper also. The low voltage plugs dont really take a lot of current also. Sorry this does not help you find what you want but it might be a better option. Regards Michael.
498660
Follow Up By: judes34 - Sunday, Nov 18, 2012 at 14:43
Thanks Michael. We're already using the 2pin type. Just lookin for a cheaper supplier.
774707
Reply By: The Bantam - Sunday, Nov 18, 2012 at 11:06
The plugs you are talking about are commonly called "T" plugs and are one of the most reliable low current Extra Low voltage plugs available.
They are derived from our 240V manis plugs and are made to the same standards.
That carr the current they where designed for very
well...that is a maximum of 15 amps, most fridges draw less than 7 so there is no problem there.
For this sort of application they are far better than anderson type plugs.
they are easy to plug and unplug, they have strain relief for the cable, they are intended specificaly for the sizes of cable you will find on fridges AND no soldering is required, therefore there is no stiffening of the cable that promotes a fracture point.
My out of date Clipsal pricing guide list the plug at $9.30 Retail..the bloke asking $18 is having a lend.
498701
Follow Up By: judes34 - Sunday, Nov 18, 2012 at 14:44
Thanks very much. Appreciated.
774708
