How to clean a blocked stove burner?
Submitted: Sunday, Dec 02, 2012 at 13:12
Stan2.8D
One of the gas burners on my Coleman stove has most of the little holes blocked solid:
I guess some milk or perhaps egg got in there and then cooked cooked.
Have tried boiling in diluted vinegar but this didnt work.
Is there anything else I could try?
thanks
Reply By: The Explorer - Sunday, Dec 02, 2012 at 13:35
Maybe try a pin/needle (making sure
debris is remove from the burner when dislodge)...or if you have access to compressed air - give it a blast.
499662
Reply By: Member - Jack - Sunday, Dec 02, 2012 at 14:01
The compressed air is a good option. If that does not clear it up you need to get some Primus Prickers to clear out the jet. These (or similar) can be bought at some hardware stores (if you can find an assistant who knows what they are talking about), but gas shops or welding outlets will have something similar . They are like tiny and very fine files. I had to clear out the jets on my camper stove and they worked a treat.
Jack
499666
Follow Up By: workhorse - Sunday, Dec 02, 2012 at 17:04
Fine fuse wire from old electrical set ups from the fuse boxes in homes from the old days are also good
775648
Follow Up By: Charlie B2 - Monday, Dec 03, 2012 at 13:39
I see from the post below that you no longer need suggestions, but, while fine fuse wire might work as "workhorse" has suggested, a steel bristle out of a wire brush crimped into a strip cut out of the lid of a fruit, baked beans or whatever, tin works a good bit better - it's stiffer and won't fold up under a bit of resistance.
Just cut a strip 6-8mm wide out of the lid, fold over the last 3-5mm of the strip, put the steel bristle into the fold and crimp it shut with pliers or vice-grips. If the bristle is long enough, you can even make a double-ended one!
Works a treat with primus lamps and old kerosene blowtorches too (if anyone still has one!).
Charlie
775697
Reply By: Stan2.8D - Sunday, Dec 02, 2012 at 15:50
Just tried the old standby, vinegar with bicarb and boiled it for few minutes; seems to have done the job.
thanks
499670
Follow Up By: Mick O - Sunday, Dec 02, 2012 at 16:14
Good job Stan. I was going to add the only success I have had with blocked jet has involved burning them hot with a butane soldering iron flame and then blowing them out with compressed air. Make sure you have a good hold of the jet with the plyers though.
Cheers Mick
775646
Reply By: bks - Sunday, Dec 02, 2012 at 19:49
Spend a couple of dollars and buy a new valve
499680
Follow Up By: The Explorer - Sunday, Dec 02, 2012 at 19:56
?...nothing wrong with any "valve"..it was the burner that was blocked (from food dripping on it).
775653
Reply By: kev.h - Monday, Dec 03, 2012 at 20:11
Soak blocked jets in a bit of Coca Cola for a few hours if out and about it works most times
Kev
499727
Reply By: Member - Terra'Mer - Tuesday, Dec 04, 2012 at 14:09
My Dad used a very unconventional method on family camps when i was a kid. He used his hair! He has very wirey hair and it was course enough to push without bending but fine enough to fit. Having shared this story over the years I have heard of people successfully using horse hair as
499771
