Leaving Water in a Hot Water Service
Submitted: Thursday, Jan 10, 2013 at 21:01
ThreadID: 99917 Views:3277 Replies:5 FollowUps:1
Hi. I have a new Jayco Outback Discovery with an electric/gas hot water system.
I have just returned home after a week away.
My question is - do I leave water in the hot water tank while the van is in storage or is it better to drain it beforehand? It will be in storage for about 8 weeks.
Thank you.
Reply By: Notso - Thursday, Jan 10, 2013 at 21:21
The instructions for my Suburban say to drain it. Never have though.
AnswerID: 502182
Reply By: Peter_n_Margaret - Thursday, Jan 10, 2013 at 22:13
Never drained our gas Truma in 8 years.
OKA196 Motorhome
AnswerID: 502190
Reply By: Member - Frank P (NSW) - Thursday, Jan 10, 2013 at 22:38
Hi garytee
There are differing opinions on this, but we store our van with full tanks (including HWS). Our reason for this is when drained the tanks don't dry out, they remain wet. Add lots of oxygen from a tank full of air, a warm climate, it must promote uglies to grow. So we store with full tanks (minimum oxygen) and twice a year we sanitise the system. Again there are differing opinions on that - different subject discussed elsewhere on this forum.
If you have a clean system(ie, recently sanitised) I think 8 weeks stored full will be ok, just depart when you're ready.
If it's been a while, either sanitise and flush it now and store full then leave in 8 weeks, or store full and sanitise and flush before you go.
My thoughts only
AnswerID: 502193
Follow Up By: baz&pud (tassie) - Friday, Jan 11, 2013 at 08:25
Agree with above, we use our van so much the hot water never gets cold anyway.
Baz
FollowupID: 778580
Reply By: pop2jocem - Friday, Jan 11, 2013 at 14:06
I drain the water from our Suburban gas HWS, remove and inspect the sacrificial electrode, replace if required. It's amazing how bad some of the water in NW of WA is (:0).
I then leave the HWS empty and top up the two water tanks with our tap water after flushing any water left after the trip.
Works for me.
Pop
AnswerID: 502249
Reply By: wombat100 - Friday, Jan 11, 2013 at 16:25
Also- check that your HWS may have an anode installed.
This needs sevicing/replacement as required!!
AnswerID: 502268
