Endless hot water
Submitted: Wednesday, Jan 23, 2013 at 18:21
ThreadID: 100147 Views:2824 Replies:5 FollowUps:0
We have just purchased a new van and have been given the choice of standard suburban hot water setup or gas only endless supply setup. Any feed back from those who have experience with the endless supply setup would be greatly appreciated.
Dean
Reply By: Member - Rosco from way back - Wednesday, Jan 23, 2013 at 19:13
I don't know about van type units, but we have an endless supply type at home. Used to be called gas geyser units. Simply a gas flame and heat exchange unit to heat the water required. Perfectly good system and possibly more compact than a storage system for your situation.
AnswerID: 503229
Reply By: Dean H - Wednesday, Jan 23, 2013 at 20:54
Thanks Rosco
AnswerID: 503245
Reply By: willys701926 - Thursday, Jan 24, 2013 at 08:18
We had one fitted to our new off road van and provided you have an endless supply of water and gas it is fantastic.
If you go the storage route read the fine print on recovery times as some we were offered looked good but needed both 240v and gas to meet the advertised recovery.
Ken
AnswerID: 503267
Reply By: Member - Rick P (NT) - Thursday, Jan 24, 2013 at 08:55
Hi Dean We often think that the gas only endless hot water system would have been a better option not that we were given a choice when we bought our van, but we spend a lot of time on 240v power so naturally we are not using our gas. The Suburban we have only has the 22lt tank and when it's cold it doesn't take long for us to run out of hot water.
Rick P
AnswerID: 503270
Reply By: Racey - Thursday, Jan 24, 2013 at 09:36
The endless HW unit are similar to a domestic instantaneous HW unit which we have at home. We find there is a delay, longer than storage type, before the hot water comes through. Therefore a lot of water can be wasted. We have Suburban gas/electric unit and find it ideal for our purposes. We free camp most of the time and could not afford to waste water. Plus you get a cold slug of water in between uses. I also believe the demand on gas would also be much higher. As someone pointed out when in a caravan park why waste your gas when you can use power that you are already paying for.
Definitely a storage unit.
AnswerID: 503274
