Tyre Pressures - 2004 Jayco Freedom Pop Top, DUAL WHEELS,Shower/Toilet
Submitted: Monday, Feb 04, 2013 at 08:52
ThreadID: 100361 Views:7350 Replies:2 FollowUps:1
Hi. Just acquired a 2004 Jayco Freedom Pop Top, DUAL WHEELS, Shower/Toilet, 21ft overall length (from Ball to rear). ATM 1974 - GTM 1869 - Tare Mass 1499.
Advice please re suitable Tyre Pressures. Tyres - Dunlop 185R 14C 8PR. Max Pressure shown on Tyre 65 PSI. Recommended pressure on Compliance Plate - 190kpa (28psi).
Plan to have normal loading equally distributed, with Water Tanks kept close to Full Capacity at all times. I have not had Rig over a weighbridge as yet.
I am aware that the recommended pressure shown on Compliance Plate of 28psi (190kpa) is when the Tyres are cold. I take it that the overall pressure would increase 4 psi when they are warmed up.
Going on trip soon on sealed roads only.
Have Safety Hitch Sway Bars fitted.
Your advice please.
Tks
Reply By: Olsen's 4WD Tours and Training - Monday, Feb 04, 2013 at 09:43
See if the following information is available on the tyre
tyre Max load (per tyre)
tyre Max pressure
Find on the compliance plate the tare and atm of the trailer
Then calculate pressures for full and empty as follows but do not exceed max pressure specified on tyre.
Full-
full load tyre pressure = atm/(number of tyres x tyre max load) x tyre max pressure + 4 psi
Empty
empty trailer tyre pressure = tare/(number of tyres x tyre max load) x tyre max pressure = 4 psi
AnswerID: 504051
Follow Up By: Olsen's 4WD Tours and Training - Monday, Feb 04, 2013 at 09:43
Sorry typo
Empty should be
empty trailer tyre pressure = tare/(number of tyres x tyre max load) x tyre max pressure + 4 psi
FollowupID: 780816
Reply By: member - mazcan - Monday, Feb 04, 2013 at 14:19
hi Isa nomads
i think you may mean tandem wheels one behind other on seperate axles
dual wheels are 2 wheels fitted side by side on same axle
i would increase pressure by 4psi if fully loaded and not rely on extra pressure build up caused by heat of rd travel
most tyres increase through normal rd friction particuly if not inflated enough for the load they are carying when cold to start with
AnswerID: 504064
