Fitting snorkel to GQ - will factory air duct leak?
Submitted: Monday, Jan 26, 2004 at 23:01
Mark
Hi All,
Will be fitting a
snorkel to my GQ 4.2 diesel soon but I've got some concerns about the ability of the connection where the duct from the precleaner joins to the main air cleaner above the engine to seal out
water. Its just a loose fitting square plastic section held in by one bolt. At least if it was a round section it could be properly clamped.
What have other GQ diesel owners done to fix this or is it not a problem?
Reply By: Truckster (Vic) - Monday, Jan 26, 2004 at 23:11
check my reply on Outerlimits to the question.
44420
Reply By: chrisfrd - Tuesday, Jan 27, 2004 at 09:55
The last
snorkel I fitted to the 4.2 GQ, I replaced the whole air box with a ZD-30 air cleaner unit, that I sourced from a wreck.
This allowed me to use the hose to connect directly to the
snorkel, by replacing the top pipe and sealing everything with silicone below the anticipated
water line.
The conversion was great, but was very fiddly.
Chris.
44447
Reply By: Hankster - Tuesday, Feb 10, 2004 at 23:39
Mark, I'm interested to know what you came up with because this was a concern of
mine with my patrol. The last
water crossing I did (in my work car - not patrol) the
water was 2 inches up the windscreen!! Not that I intend to do this in my private car. Any advice.
Thanks Hank
46256
