Help with a Icom IC400Pro
Submitted: Tuesday, Jan 27, 2004 at 01:15
Mike
If you own an Icom IC400PRO how do you programme in the 88 extra RECEIVE ONLY channels, do you need a computer/software to do it OR do you do it via the front buttons/knobs? Regards Mike
Reply By: chenj3 - Tuesday, Jan 27, 2004 at 15:33
Hi , Mike
I bought IC400Pro last week after did my research on this Web site. from what I know you need to bring your unit to authorised dealer to program your unit to receive/transmit 25 watts of extra 88 channels. also a license is needed to operate these 88 channels.
I used this uint during this long weekend and found it is second to none.
44476
Reply By: Vojta - Tuesday, Jan 27, 2004 at 20:13
Mike
I am looking at getting the same unit, and as best I gather from all sources, the extra 88 channels can be programmed both from the front panel, or using additional cables and pc software. Look in the back of the instruction booklet to see how to do it, apparently its burried there somewhere. You don't need a license to program these 88 channels, since (i guess) they are receive only and you can do no harm since you cannot transmit on them. As far as going upto 25watts a dealer is probably best to do this and its at this stage that you probably need a licence to transmit at this power output.
vojta
44528
Follow Up By: Vojta - Tuesday, Jan 27, 2004 at 20:15
also beside the hassel with programming, how do you find the rest of the unit ???
Vojta.
306701
Reply By: vk3xem - Thursday, Feb 12, 2004 at 23:22
Check out
http://www.ic400pro.com/
it has all the information you will ever need on this radio.
73 de Simon, VK3XEM.
46546
