Monday, Feb 18, 2013 at 11:33
Hi Guys
I fitted and wired my panels to the van during its build. (builder was running out of time but that's another story.
I fitted my panels to Tee section ally strip.
I cut 3 lengths about 100mm longer than the panels.
I secured the ally Tee top down to the roof with SS Screws and Sealant.
The spacing between the leg of the inverted Tee section was 12 mm greater than the panel.
I mounted the panel on timber blocks to give a 12mm
gap between the roof and the base of the panel.
I then used a silicon sealant to fix the panels to the Tee section.
After the sealant had cured I removed the small 12mm spacer blocks.
Now the panels are suspended on the leg of the tee section.
This allowed for the following to happen.
Expansion.
Vibration
To date I have had no issues with the panels moving.
If ever I need to remove the panels its a simple process to split the sealant with a knife of a length of nylon.
Clean up the surface and start again with the install of the repaired/replaced panel.
Geoff
781896
