thinking of a body lift
Submitted: Tuesday, Jan 27, 2004 at 22:12
Member - Eric
has anyone here had any experience with a body lift on a 80 series ? I have a 5 inch suspention lift and was hopeing to get another 25 to 50 mm in a body lift .
With a 25 mm lift is the L/R selector going to have problems with the tunnel ? and will the radiator need shifting ? if anyone here has done one , I would love to hear your input
Venus Bay
Reply By: Truckster (Vic) - Tuesday, Jan 27, 2004 at 22:13
www.lcool.org
on the GQ, you cut a V out of the floor for the L/H shifter
Remove the radiator lower shroud section.
44555
Follow Up By: Member - Eric- Tuesday, Jan 27, 2004 at 22:15
Have you seen one done Truckster ? I was hopeing to get away with not shifting bullbars or rear barVenus Bay
306716
Follow Up By: Truckster (Vic) - Tuesday, Jan 27, 2004 at 22:33
Thats the other bit u will have to do..
Measure the distance from the bar to the lights, see if they will clear or foul.. otherwise your ok.
its not a hard job, ripping
mine out in a week, takes about 4-6 hours on a GQ with beer, theres a howto on my site www.gqpatrol.com that may give you a better idea.
306720
Follow Up By: Member - Eric- Tuesday, Jan 27, 2004 at 22:50
i had a look at the L/C sight you sent me , nothing there . I will have a chat to the boys in Epping tomorrow
did you get my reply on your insurense woes ?
Venus Bay
306723
Follow Up By: Truckster (Vic) - Wednesday, Jan 28, 2004 at 12:09
Yea was talking to Rod the other day, gettin my Diffs done there soon, 4.6's I think, or 4.3 not too sure yet..
306765
Reply By: Willem - Tuesday, Jan 27, 2004 at 23:00
Now tell me Eric....does this lift have some use OR is it pose value only :-)))
Willem
Googs Lake
camp
44571
Follow Up By: Member - Eric- Wednesday, Jan 28, 2004 at 08:36
I want to fit 35 's without them scrubbing WillemVenus Bay
306746
Reply By: Member - Royce- Tuesday, Jan 27, 2004 at 23:35
If it's the same as the 75 series I lifted [below], the steering column had enough extension to handle the 2" lift, but the radiator needed to be dropped and remounted so the cowling would stay the same in relation to the fan. Royce www.funshow.com.au
44577
Reply By: Member - DOZER- Wednesday, Jan 28, 2004 at 06:08
Hi Eric
There will be heaps of info on lcool, apparently easy job, 1 inch can be done with most std bolts, (moving them forward 1 hole) 2 requires rad support bolt holes to be redrilled, with bigger tyres the body does need to go up, can do other tricks to get the fronts forward like the caster bushes replacing the front arm pivot bush.
If u want i have a set of 6 inch dobson springs/shox/pannies/extensions /etc etc etc i dont use anymore.
Andrewwheredayathinkwer mike?
44582
Follow Up By: Member - Eric- Wednesday, Jan 28, 2004 at 08:37
could you please email me what you have and what you would want for them ?
wholesalecars@optusnet.com.auVenus Bay
306747
Follow Up By: Truckster (Vic) - Wednesday, Jan 28, 2004 at 12:04
Eric..
I can back up Andrew here, he is good to deal with, got some spotties off him about 18mths + ago from Sold.com.au, came with relays, switches, cable, more than I expected..
Hes in
Wollongong area South of bleep ney.
306764
Reply By: jules15 - Wednesday, Jan 28, 2004 at 08:22
What first? - boobs? bum - tummy tuck!! oh sorry wrong body
44588
Reply By: Coops (Pilbara) - Tuesday, Feb 03, 2004 at 15:25
Eric
I did a 50 mm lift about 4 months ago.
Send me an e-mail to allyn dotcom dotau and I'll give you contaxct details then you can call for a chat.
If not I'll post details when I get time
45307
