Endless Air for a 100 Series TD
Submitted: Wednesday, Feb 27, 2013 at 21:34
Idler Chris
Has anyone had one of these fitted lately, and if so where? I am in
Melbourne. Looking back through the
Forum it would appear that the mounting brackets have been a problem in the past. I would like to know if they are still a problem or if the manufacturer has fix the problems.
| What other people think of me is none of my business.
The word "hate" is not in my vocabulary. Lifetime Member My Profile My Blog My Position Send Message |
Reply By: Life Member - Phil B (WA) - Wednesday, Feb 27, 2013 at 22:01
Hi Idler
I got my kit from Air On Board (this is not endless air)
- here's the ebay link, the got to the
shop and look around.
Mine is three years old, its bullet proof, never moved and never failed.
http://www.ebay.com.au/itm/Air-compressor-engine-kit-031-ARB-Endless-Air-TJM-board-kit-HDJ-landcruiser-/290833623596?pt=AU_Car_Parts_Accessories&hash=item43b708ea2c
505710
Follow Up By: member - mazcan - Wednesday, Feb 27, 2013 at 22:12
hi phil b
that listing has been removed from ebay site
782656
Follow Up By: Idler Chris - Wednesday, Feb 27, 2013 at 22:39
I had the same problem, but if you copy and paste the link directly into a browser it works.
It looks like the mounting kit costs $425 & compressor $325. Any idea the approx cost of other parts required (hoses etc) and labour to fit?
782660
Follow Up By: Life Member - Phil B (WA) - Thursday, Feb 28, 2013 at 01:28
Hi guys
I found them very approachable. use the email contact thru ebay and they'll get back to you really quick. Specify what you want and they'll tell you what you need, which of the compressors fit your motor etc. cost it and give you a total price.
They only supply kits and parts and don't fit; I installed
mine and I'm not that adept with spanners I can assure you.
782666
Reply By: Member - John - Thursday, Feb 28, 2013 at 10:15
Have an Air Onboard compressor, much better quality than Endless Air brackets etc. John
505727
Reply By: kev.h - Thursday, Feb 28, 2013 at 19:39
Hi Chris
I fitted one of these 3.5 cfm + 200 psi just need a place to put it. The endless air was just too difficult to fit to my vehicle
http://www.bossglobalinc.com/compressors.html
- go to air
suspension section then compressors
Cheers kev
505769
Reply By: Idler Chris - Thursday, Feb 28, 2013 at 21:29
Thanks everyone problem sorted. I rang Air on Board and spoke to John who was very helpful and gave good advice. I currently have an on board 12 volt compressor and a 6 litre
tank mounted under the truck. There are air outlets at both end of the vehicle and inside on the cargo barrier, they also feed the air lockers. John has told me how to fit their 1024 belt driven compressor and connect it to my current system so I can use either compressor. The very best 12 volt compressor still take a while to pump up 4 tyres which means you do not always change your tyre pressures as much as you should. I have tyre monitors and if your tyre pressures are not right for the conditions the tyre heat up very quickly which is bad for their longevity. At a cost of nearly $800 this compressor is not cheap. I have also just brought 6 new General Grabbers AT2 costing $1,600 so I figure this new compressor should pay for itself over two sets of tyres with the bonus of always having the tyres at the right pressures and so maximum traction and all benefits that brings.
505777
