Boat Loader Motor
Submitted: Saturday, Mar 02, 2013 at 13:20
ThreadID: 100851 Views:3475 Replies:6 FollowUps:1
Im looking to build a boat loader for my car and i need to know what size motor i will need to lift a Quintrex 3.75 mt boat which weighs around 100kg.
Baker
Reply By: member - mazcan - Saturday, Mar 02, 2013 at 13:37
hi humpback
unless you have a disability
would'nt it be simpler to use a hand winch same as used on boat trailers that way you iliminate the need for battery power /cables and handheld remotes after all 100kg isnt very much weight for a hand winch and no doubt will be avaible on ebay and bcf
just my thoughts
AnswerID: 505897
Reply By: Member - ACD 1 - Saturday, Mar 02, 2013 at 14:03
Baker
I don't know if this will help, but another member, Scrubby, posted a blog showing the boat loader he made using his existing winch.
Scrubby's Boat Loader
Anthony
AnswerID: 505899
Reply By: Notso - Saturday, Mar 02, 2013 at 15:12
I've seen em using battery powered drills to power them.
AnswerID: 505906
Reply By: Member-Heather MG NSW - Saturday, Mar 02, 2013 at 20:09
Hi Baker,
I know this does not answer your question but we have a 'Rhino' side boat loader and use a good quality drill to power it to load/unload our tinny. Its not as heavy as yours though ( ours is around 75kgs) but does a great job.
cheers Heather
AnswerID: 505920
Reply By: Hopper-51 - Saturday, Mar 02, 2013 at 20:10
You may find a 100kg boat plus the rack on top of your vehicle with be too great a load. A landcruiser can carry 100kg on its roof but most other 4wd's cannot.
AnswerID: 505921
Reply By: Member - bungarra (WA) - Sunday, Mar 03, 2013 at 11:12
The motor's most commonly used are simply starter motors direct coupled to a reduction gearbox.
Choosing the correct ratio will need to be sorted out
Have you thought of using a cheap electric winch off ebay?. I have one (3000kg) with a remote control for less than $100 that I use to lift my boat loader off and on the roof of the 'cruiser..........with some ingenuity one of these can easily be adapted to a boat loader............same concept as scrubbys boat loader except he uses the bull bar one
as for using power ...why not just keep your engine running.....when in use the power draw/use is irrelevant...and very low anyway
VKS 1341
AnswerID: 505954
Follow Up By: kev.h - Sunday, Mar 03, 2013 at 12:04
The winches they make for quad bikes work perfectly they are small and compact this is the one I have used
http://ezpower.com.au/products.php?product=winch-2000lbs-with-remote-switch-for-250-cc-atv-quad-bike
Cheers Kev
FollowupID: 782865
