Fault codes for VDJ78R 1vd-ftv engine
Submitted: Thursday, Mar 07, 2013 at 22:45
ThreadID: 100951 Views:10891 Replies:3 FollowUps:2
Hi all,
Am looking at fitting a scangauge and would obviously like to have a list of the fault codes for my troopy. Could be handy out the back of beyond.
Anyone have a list or know where I could obtain them?
Craig
Reply By: Member - bungarra (WA) - Thursday, Mar 07, 2013 at 23:27
quite easy to find on Google
here is a start
http://www.obd-codes.com/trouble_codes/toyota/
VKS 1341
AnswerID: 506291
Reply By: Crackles - Thursday, Mar 07, 2013 at 23:42
If you have a smart phone you many consider a bluetooth OBDII transmitter for $20 & use the "Torque" app to read/clear trouble codes plus display all engine data.
Scanner tool.
Cheers Craig..................
AnswerID: 506294
Follow Up By: Member - John (Vic) - Friday, Mar 08, 2013 at 00:51
Craig do you have a link to that particular app?
Searching through the App Store there seems to be quite a few OBD2 apps but can't see "Torque"
Are you using that system??
FollowupID: 783227
Follow Up By: Member - John (Vic) - Friday, Mar 08, 2013 at 01:17
Ahhhh!! Found it!
Torque is an Android app, hence why it wasn't in the ITunes apps store.
Seems to be similar to a few app offerings for the various iPad & iPhone devices.
FollowupID: 783229
Reply By: olcoolone - Friday, Mar 08, 2013 at 08:26
Just bear in mind there a two types of fault codes for OBD2...... normal and enhanced.
Generic code readers like the scangauge only reads normal OBD2 codes, normal OBD2 codes are more related to emission components whereby OBD2 enhanced is more vehicle specific like transmission, ABS, traction and VSC, body control, HVAC.
AnswerID: 506310
