Dyneema Equalizer Strap
Submitted: Monday, Mar 11, 2013 at 23:06
Member - Brian A (QLD)
Just purchased a winch fitted with Dyneema Rope and thought I would purchase an Equalizer Strap to go with it. My searches have been unsuccessful. Does anyone know if such a thing exists and better still where I can purchase one from.
Thank You
Brian
Reply By: PajDIDauto - Monday, Mar 11, 2013 at 23:16
Hi Brian, Winch equaliser straps are available from most 4wd accessory retailers. Try TJM, Opposite Lock or ARB.
506605
Reply By: gbc - Tuesday, Mar 12, 2013 at 06:53
I doubt you'll find one. Dyneema melts at 140 degrees and has very little abrasion resistance. The kind of friction an equaliser is subjected to would kill dyneema very quickly.
506612
Follow Up By: garrycol - Tuesday, Mar 12, 2013 at 11:32
ARB sell them and I have seen them used - they have no problems
783638
Follow Up By: Idler Chris - Tuesday, Mar 12, 2013 at 13:01
I agree with gbc a Dyneema equaliser strap would not be suitable on all occasions for the reasons given. I use a 12000lb rated webbing strap and it is safe and reliable.
| What other people think of me is none of my business.
The word "hate" is not in my vocabulary. Lifetime Member My Profile My Blog My Position Send Message |
783648
Follow Up By: gbc - Tuesday, Mar 12, 2013 at 13:02
Just checked. Arb now only do dyneema equalisers. They had probs with the webbing straps. Live and learn eh.
783649
Follow Up By: garrycol - Tuesday, Mar 12, 2013 at 13:28
I believe they come with an anti chaff sleeve to get around any possible issues.
783651
Reply By: Ultimate 4WD Equipment - Tuesday, Mar 12, 2013 at 11:04
A standard nylon equaliser strap is a much better proposition for winching duty. They are usually 75mm wide and offer plenty of strength and abrasion resistance. And they are much cheaper.
506628
Reply By: Idler Chris - Tuesday, Mar 12, 2013 at 12:54
All the equaliser straps I have seen seem to be a shorter tree trunk protector, 2.5 mt for the ES and 3mt for the TTP. I would think a tree trunk protector would do the job OK, certainly better than nothing. Does anyone know of a reason not to use a TTP as a ES?
506632
Follow Up By: garrycol - Tuesday, Mar 12, 2013 at 13:35
Tree Trunk Protectors are usually used when winching where loads are much lower than a heavy snatch so if using them in a snatch they will need to be rated similar to the snatch strap.
I actually use them as an equilizer - if being winched I use one as an equilizer but use two when snatching as my TTP are only rated at 4500kg where my snatch strap is 10000kg. I am looking at getting a synthetic rope equiliser strap.
783652
Reply By: CraigB - Tuesday, Mar 12, 2013 at 14:10
I've had a Dyneema equalizer for about 3 years now. It's been used many times without any problems whatsoever. I would highly recommend one.
506639
Reply By: Member - Hillel K (VIC) - Tuesday, Mar 12, 2013 at 17:46
Hi there
TJM make an equaliser webb strap
506656
