2007 3 litre turbo diesel Nissan patrol wagon
Submitted: Sunday, Mar 17, 2013 at 15:40
spaanderman65
Hey everyone I am looking at a 2007 Nissan patrol wagon with about 200000 kilometres on the clock. Is there any known problems with these? Thanks
Reply By: bluefella - Sunday, Mar 17, 2013 at 17:30
There has been, mainly holes blown in no 3 or 4 piston. Although there is sill plenty getting around that have had no problems, some with high mileage.have a look on the patrol
forum website plenty of info there.
506994
Follow Up By: bluefella - Sunday, Mar 17, 2013 at 17:34
I should add these may have been earlier models?
784127
Follow Up By: DiscoTourer - Monday, Mar 18, 2013 at 23:27
Blue....the key to his post was 2007. The GU1 & 2 issues have been done to death on this
forum and others.
Brett....
784249
Reply By: Dough Boy - Sunday, Mar 17, 2013 at 20:43
If its a 2007 I am guessing it is the "Common Rail " engine which had very few problems .
If it has a service history that will tell a story. If you can find out its towing history that will help
Many of these cars were used to tow weights sometimes beyond what they were capable of and thats when the engine damage was done
507005
Follow Up By: bluefella - Monday, Mar 18, 2013 at 07:31
2007 is the same ZD30 direct injection as earlier models. I'm told nissan did a few mod's on these latter engines?
784165
Reply By: patsproule - Monday, Mar 18, 2013 at 10:49
The common rail ones still go bang. Have a good read through patrol4x4.com. Particularly the ZD30 sub-forums of the GU section.
Pat
507030
Follow Up By: Teejay - Monday, Mar 18, 2013 at 14:31
I reckon if you read through the patrol4x4.com ZD30 sub-forums of the GU section you'll find about one or two CRD's that have gone bang. And pretty much unconfirmed if there detonations were for the same reasons as ZD30's.
They don't have the same holing of piston issues that the original ZD30 had. Having said that they come with a whole other range of drama's thats have already been pointed out here.
Check out to find if it has a new clutch installed. The original duall mass flywheel clutches are rubbish.
784196
Reply By: olcoolone - Monday, Mar 18, 2013 at 12:05
What about the chassis cracking, the rear door cracking, the front diff housing cracking, the compressor pulley bearing going noisy, intercoolers leaking and.......
apart from thoses thing and the engine they are fine.
507037
Follow Up By: Mark S (cns) - Monday, Mar 18, 2013 at 12:37
Spoken like a true toyota enthusiast:)
784187
Follow Up By: olcoolone - Monday, Mar 18, 2013 at 15:24
Nothing wrong with the truth, Toyota have had a few problems too...... Difference is Toyota seem to fix their problems.
We buy cars that suit our needs and we are not loyal to any brand.
Just some are made better than others!
784203
Reply By: TerraFirma - Monday, Mar 18, 2013 at 14:40
Hi Spanderman, I'll attempt to give you a clear answer. The 3 Litre engine has had it's problems, it can self destruct. Without pre judging the vehicle your looking at given it has already done 200,000KM's the thousand dollar question is how many KM's does it have left? 50,000?? As mentioned above check the service history, was it doing fairly heavy towing? One can only try to do normal due dilligence on the vehicle to ascertain if it will be a viable purchase going forward? Have the vehicle tested, engine tested etc and consider the purchase price as you are buying a vehicle that has the potential to cost money as it gets toward the end of it's life span.
507042
Follow Up By: robert s4 - Saturday, Apr 13, 2013 at 03:17
so u think the the 3 litre will only have last 200000
786502
Follow Up By: TerraFirma - Saturday, Apr 13, 2013 at 10:38
Nice sentence Robert makes no sense, read the comments properly.
786521
