Tuesday, Mar 19, 2013 at 11:02
Arsenal Phill
Only a week or two back there was much discussion about this issue.
It sounds like you need someone to pump out your
tank with and external pump with the sucking pickup positioned at the lowest point in the
tank Ie tilted to side and forward.
You will need to treat your
tank with a fungicide additive to kill the nasties though.
After that you can then fit an additional filter to add some security to the issue.
There is some dispute about waterwatch filters. They are very good at detecting the
water, not sure about the crap though. They detect
water but don't actually try to stop
water continuing n the system so once it signals then the absorbed
water in the
fuel ie, emulsified
water is already knocking on the door of the original filter and possibly got through it too. It just tells you
water is there, so more an indicator , which is good, but not a preventer AFAIK.
My view is to have something which at least attempts to dewater the
fuel and also filter it.
This filter will be a few microns bigger than the OE filter and therefore filters out the major amount of crap and also dewaters as much as possible.
This leaves the OE filter then to do the final sweep for finer particles with out being swamped by large amounts of bigger sized particles.
I like the idea of a large pre filter or two smaller ones. This will allow time for the
fuel to be running slower through any filter there and it will have a greater effect in removing both
water and particles. Two filter will also present less restriction to the
fuel system and negligible restriction will be experienced by the HP pump. They don't like being starved at all.
Anything you add will begin to provide some level of additional insurance, I prefer the multi tasking filters ie
water removal and filtering. Just knowing
water is in the system isn't everything.
Ross M
507115
Follow Up By: Member - Arsenal Phill - Tuesday, Mar 19, 2013 at 16:45
Ross. Brilliant information and advice. I'll do some follow up and see where I get!!! LOL
I really appreciate you taking the time.
Take it easy, be lucky
784320
