Wednesday, Mar 20, 2013 at 20:28
G'day Tastpa
I talked to you a while ago when thinking of selling my Tvan.
I had rust in the rear loop pipe. it is powder coated on the outside but not on the inside and
water from the sky just falls in and rusts the innards because they don't put plugs in the ends.
I bought some good rust converter and fed a wire through the pipe. On one end I attached a piece of sponge and pulled it slightly down the tube. Onto that i poured the rust converter and it also ran through the sponge and into the pipe.
With the bit above the sponge wet with converter and plently in the tube the sponge was then dragged through to the other end.
The pull through was then reversed and it travelled the other way through.
This coated the innards with converter and then after drying the ends were plugged.
Not sure if Track will go to that much bother though.
You are a purchaser of a second hand Tvan and I would think the same affection will not be forwarded to you as it would be to the first owner.
Check your brake lining thickness, brake adjustments and bearing adjustments for good operation of the system.
I modified the floor so it doesn't flex when standing in the middle at the join.
Also cut off the tang section of the hooks on the tent Zipped mesh cover.
This allows a one handed hookup of the cover when packing the tent into the rear door.
I added a car
fuel tank to the underside of the Tvan, 60 litres with it's own internal pump which can be used for distance touring and the pump can be used to pump directly into the vehicle
tank as required.
Check on yours up at the roof near the hatch hinges and make sure there is no bare edges of ply showing where the edge meets the fibreglass and top moulding.
Mine required sealing as it completely missed the factory "quality" check.
There were a number of other build issues too, which had to be rectified. Make sure all edges where Sikaflex is used to bond and seal are actually bonded. In some areas
mine was sadly lacking and I could post a letter through the "bonded" area ie floor to side at rear. Builders didn't remove the oily surface on steel sheeting before adding Sikaflex, therefore no bond at all.
Where do you live? Locals may be of assistance.
Ross M
507224
