Clean water tanks
Submitted: Tuesday, Apr 02, 2013 at 18:40
Member - Grundle (WA)
Hi ,Whats the best way to clean the campers
water tanks. Thanks
Reply By: IronMan - Tuesday, Apr 02, 2013 at 18:56
Miltons. Or fill with clean
water and add about 100ml of household bleach. then drain and rinse.
508042
Reply By: landed eagle - Tuesday, Apr 02, 2013 at 19:06
I've done my van's tanks using the powder for cleaning plastic homebrew bottles. Half a bottle in each
tank,fill and let stand for a day or two. Drain and refill.
508044
Follow Up By: Member - Grundle (WA) - Tuesday, Apr 02, 2013 at 19:53
Thanks,Ihave some of that.
785442
Reply By: Member - Frank P (NSW) - Tuesday, Apr 02, 2013 at 21:51
1ml of household bleach per litre of
tank capacity. 70 litre
tank, 70ml of bleach, etc. Pour the bleach in, fill the
tank, run all taps and pumps to get the treated
water through the system. Leave for 6 hours then flush and refill.
I also store the van with tanks full (of fresh
water, not the above).
508056
Reply By: The Bantam - Wednesday, Apr 03, 2013 at 00:08
Any of the marine shops will supply you with products specificaly for cleaning
drinking water tanks.
Bleach may seem to be a good idea, and it may knock down the initial smell & taste...and it indeed may knock down any growing allge or fungus...but bleach does not kill spores.
For a single non branded product, citric acid may be more effective and leave less lingering smell & taste.
What ever you use, its a good idea to take the van fro a drive arround the block.....over some speed bums will be good, to slosh the contents arround.......otherwise no cleaning at all will occur on the roof of the
tank.
The sloshing will also help dislodge any particulate material adhering the the inside of the
tank
508064
Follow Up By: Allan B (Member, SunCoast) - Wednesday, Apr 03, 2013 at 10:51
Hey Bantam......."some speed bums"???
Are they race car drivers?? lol
785476
Follow Up By: The Bantam - Wednesday, Apr 03, 2013 at 11:34
Even driving over a speed bump at ldle in low first will slosh the
water arround in the
tank plenty...and for good benifit...especially diagonally.
I doubt that any of our sensible readers with try this at speed.
Hell I'd get the same result just getting out of my driveway.
785479
Follow Up By: Allan B (Member, SunCoast) - Wednesday, Apr 03, 2013 at 12:31
It was a joke Bantam.
Re-read your original post (Reply 4) carefully, minding the bums, err bumps!
Cheeee, Lead balloons!!!!!
785482
Reply By: martin c1 - Wednesday, Apr 03, 2013 at 18:17
I found green algae growing in my clear plastic undervan hoses. After the chlorine treatment, algae died, sloughed off and disabled the check valve under sink. You might check this out before leaving home. I had to dismantle all clear plastic hoses. I wrapped them in black plastic and have had no trouble since. Regards, marty.
508099
