Landcruiser beeping
Submitted: Sunday, Apr 07, 2013 at 20:34
mac3
Hi all,
Not sure if this is pertinent to exploring oz but I've asked the question on 4wd
forum with no luck, I'm sure someone here can answer it. I have 2003 Landcruiser Sahara which started beeping when turning off ignition. Runs
well, no dash lights, all good but turn off engine and I get 2 short1 long beep repeated 3 times. Some googling tells me sunroof is open-no, or perhaps a problem with the key (what problem?) Any comments valued thanks.
David
Reply By: Member - Hunter Gatherer - Sunday, Apr 07, 2013 at 20:45
check out LCOOL site which will probably have an answer to your question. You might have to join.
508440
Reply By: Tim - Sunday, Apr 07, 2013 at 20:45
Stock stereo or aftermarket?
508441
Follow Up By: jacent - Sunday, Apr 07, 2013 at 21:50
MY STEREO (AFTERMARKET) BEEPS WHEN I TURN THE IGNITION OFF AS
WELL AS MY AFTERMARKET TEMP/ PYRO GUAGES
785980
Reply By: mac3 - Monday, Apr 08, 2013 at 13:46
Thanks guys, will try LCOOL. Factory stereo fitted, nothing has changed from no beep to beep.
508475
