Central locking remote control
Submitted: Monday, Apr 08, 2013 at 16:35
ThreadID: 101574 Views:2333 Replies:4 FollowUps:4
One of the remotes for my Landcruiser (2001) has died. No. It's not the battery. Part of the board inside has broken off. Can anyone recommend where I can get a replacement from (apart from a Toyota dealer) in Perth's northern suburbs or on line.
Terry
Reply By: Member - Toyocrusa (NSW) - Monday, Apr 08, 2013 at 19:11
Hi. Have seen plenty on ebay if you have a look for your model. Bought one for a HiLux and the guy coded it a couple of years ago. Cheers,Bob
AnswerID: 508490
Follow Up By: BUSTED100 - Monday, Apr 08, 2013 at 19:17
eBay, I just picked one up $56 delivered. Program it yourself, it takes 30 seconds;
FollowupID: 786048
Follow Up By: Member - PJR (NSW) - Monday, Apr 08, 2013 at 19:48
Please tell me more about the programming.
One of ours is dicky. The switch comes loose. I havve cleaned it with the correct solution and resoldered it with a cleaned soldering iron but it still comes loose after a while. There has to be some kind of contaminant in there that even the propyl (spelling) cleaner wont remove.
PM tyo: vk1dx@bigpond.net.au if you wish.
FollowupID: 786049
Follow Up By: BUSTED100 - Monday, Apr 08, 2013 at 22:52
picked my remote (genuine toyota remote) of ebay - oz key automotive
programming is;
1.with a working remote unlock the car;
2.leaving the door open lock it with the remote and then unlock it with the remote;
3.turn your key from off to acc and back 20 times within 20 seconds ending back in the off position;
4. your blinkers will now flash 20 times, just after the 20th flash press the button on all your remotes (3 max)
5.turn your key back to acc to leave the programming state
try your remotes. I've had to sort both my 105 and 100 now, and normally mess up the first attempt
FollowupID: 786064
Follow Up By: Member - PJR (NSW) - Tuesday, Apr 09, 2013 at 07:22
I thank you sir. I paid heaps when I had to get a second key from Toyota.
FollowupID: 786069
Reply By: Member - ACD 1 - Monday, Apr 08, 2013 at 22:16
Hi Terry
If it is an aftermarket setup, you could try:
Ashley Group
9249-1234
1 / 21 Harris Road, Malaga, WA 6090
www.ashleygroup.com.au
sales@ashleygroup.com.au
They have a huge range of remotes and will code them on the spot
Anthony
AnswerID: 508507
Reply By: Member - Jim R (ACT) - Tuesday, Apr 09, 2013 at 13:10
I had the same problem with one of mine recently but I am fortunate enough to have a mate in the electronics industry and he was able to solder the loose component back on to the board - now works like a new one.
AnswerID: 508567
Reply By: Member -GraySand - Tuesday, Apr 09, 2013 at 22:52
Hi Terry
I would also suggest that you try Ashley Electrical. I have used them in the past for new remotes and they have given good service
Graham
AnswerID: 508612
