Monday, Apr 15, 2013 at 17:08
If you are going to connect to the Ctek then it will be necessary to bypass the MPPT's on the panel's as it's pulsing and sensing output is not a form of power delivery the Ctek will like to see.
The MPPT's on the panels means you have the regulator at the maximum distance from the battery and it then has the cable run as a resistance between it and the battery it is trying to sense the voltage of. Not the best situation.
Both styles of regulator like to see clean DC input, not something which is on and then off and also trying to sense voltage levels.
If the solar is connected to the Anderson and using the Ctek, then it can't be also connected to the vehicle battery at the same time, if the panel regs are bypassed.
You have a number of possible connections and operational configurations here and there are many explanations to try and cover all possible situations.
After you decide which way it will be used then people can more accurately determine their advice.
Ross M
786743
