Select lever
Submitted: Tuesday, Apr 16, 2013 at 12:23
Member - The Drifters
Has anybody had troubles with Nissan 2000 Gu Wagon ZD30 Auto select lever sticking in the
park position.I can release it by pressing the select lever lock but it does not fix the problem.When you go from
Park to Drive and back to
Park it locks up again.If I cannot fix the problem myself I may have to take it to someone in my local area to have it checked out.Thanks for any suggestions.
Bill
Reply By: Member - The Drifters - Tuesday, Apr 16, 2013 at 13:01
Problem solved. Accidenty fixed it so all is good.
Bill
509128
Follow Up By: pepper2 - Tuesday, Apr 16, 2013 at 13:06
Glad you fixed it,
mine failed and nissan replaced the entire t bar assembly roughly $1000 but covered under warrenty.....be very sure it is perferct because if it fails again you will most probably not be able to moove the vehicle
786818
Follow Up By: Member - The Drifters - Tuesday, Apr 16, 2013 at 15:03
Thanks mate I will keep a close Eye on its action and if it looks like playing up again I will have it checked out.Cheers
786840
Reply By: Dr Hook - Tuesday, Apr 16, 2013 at 14:05
Just by putting your footo n the brake?
Hook
509133
Follow Up By: Member - The Drifters - Tuesday, Apr 16, 2013 at 14:59
Tried that a few times and relalised that was not the problem but worked it out and works fine now. Thanks.
Bill
786839
Reply By: Member - Peter M (QLD) - Wednesday, Apr 17, 2013 at 07:33
My 2001 GU does this too.
No rhyme nor reason: will stick regularly and then not do it again for weeks. This has been happening for more than 2 years. Touch wood it isn't serious.
When I have saved up enough pennies I will go to a Nissan dealer for a service (maybe Wayne Swan will borrow some more money and give us all a hand out,ho ho) and ask them. In the meantime I will continue getting the GU serviced by good bush mechanics in the little towns I pass through.
PeterM
509195
Follow Up By: Member - The Drifters - Wednesday, Apr 17, 2013 at 12:46
G/day Peter
I will be taking the Gu for a 600 k run this Saturday so I will give it a workout along the way to see if it is a repeat problem and if it is I will get it sorted out If you get something done to your Gu I would be interested to know how the problem was fixed and I will do likewise if
mine bails up.Thanks Pete and cheers. Bill
786957
