Battery issues
Submitted: Thursday, Apr 18, 2013 at 21:53
ThreadID: 101767 Views:2616 Replies:2 FollowUps:10
Hi all I have issues with my battery overheating and letting off steam. Voltage is sitting between 13.6 - 14.0 volts which was tested over 45 mins. Can anyone recommend a new battery that I should purchase? I'm assuming the alternator should be fine. Taking the car to the local mechanic tomorrow to have suspension fitted.
Thank you
P.S it is a d40 2010 Nissan Navara. Sorry.
Reply By: Member -Toonfish - Thursday, Apr 18, 2013 at 21:57
battery is cactus
how many amps are going in to the battery?
is the battery a din 66 size euro battery
i regularly use delkor as a cranker
depends on where you are as to price and availabilty
the delkor silvers crank a little more but the standard calcium is fine
2013/14 around oz adventure bound
AnswerID: 509284
Follow Up By: Wolfy03 - Thursday, Apr 18, 2013 at 22:14
Thanks for that 14volts going in. Not too fussed on price...tax deductable anyway. How do u tell what size it is??
FollowupID: 787092
Reply By: The Bantam - Thursday, Apr 18, 2013 at 22:19
If its letting off "steam"......um that will be acid mist buddy be careful.....I assume its a screw top battery.
Is that "steam" coming out of one or more cells and is the electrolite level down in one or more cells more than the others?.....In that case the battery has probably dropped a cell.
Now with the engine turned off and the battery at rest for at least 15 minutes...what is the terminal voltage?.......if it is other than 12 - 13 volts ( realy about 12.5 volts) .....particularly considerably less like 10 to 12 volts ..its dropped a cell.
If the battery is boiling its head off in all cells and no cell is dramaticaly down on fluid more than the others....AND...ya resting voltage is around the 12.5 ish no lower.
Your alternator may be over changing......ya battery may still be $#@!&...um unservicable.
Always get ya alternator checked when fitting a new battery.
Now what battery to buy....cheap is bad value.....don't wast ya time on anoter screw top unless you are selling the car.
If it takes a standard N70 battery like most 4wds ( that is a batterey about 300mm long about 180 wide and about 200 high....and has N & 70 in the part number.
My prefered is the Supercharge Seamaster Gold marine battery in the same size.
AnswerID: 509286
Follow Up By: Ozbod - Thursday, Apr 18, 2013 at 23:38
Whats with the "ya, ya, ya". Its YOUR'E
FollowupID: 787095
Follow Up By: DiscoTourer - Friday, Apr 19, 2013 at 00:29
Your'e...you meant to say your!
Sorry, but could not help myself when your'e slightly wrong.
Brett....
FollowupID: 787099
Follow Up By: Ross M - Friday, Apr 19, 2013 at 08:52
Ya often means YES, so he is unlikely to have a YES battery or a YES alternator.
FollowupID: 787110
Follow Up By: Notso - Friday, Apr 19, 2013 at 11:38
Your'e, I think you meant you're as in You are, or your as in having ownership of!
FollowupID: 787137
Follow Up By: Member - Russler - Friday, Apr 19, 2013 at 13:18
Wow, did the Grammar Gestapo finish the morning crossword, get bored and go looking for trouble? I thought Bantam's reply was perfectly understandable, and very helpful.
FollowupID: 787153
Follow Up By: The Bantam - Friday, Apr 19, 2013 at 14:16
Ozbod mate...if poor spelling, bad grammar, abbreviations and slang bother you.....DON"T READ INTERNET FORUMS.
FollowupID: 787161
Follow Up By: Notso - Friday, Apr 19, 2013 at 14:58
Well I wasn't having a go at Bantam, but the response from Ozbod etc! I figure if you're going to be holier than thou, then you should get it right!
FollowupID: 787169
Follow Up By: DiscoTourer - Friday, Apr 19, 2013 at 15:03
Guys...it should have only been taken tongue in cheek....that was the intention.
Brett.....
FollowupID: 787171
Follow Up By: Wolfy03 - Monday, Apr 22, 2013 at 21:23
Following up on a serious note. Alternator is fine - battery is replaced with a Bosch sealed. Very happy with it. Also got to test the new suspension out on the bus! One very happy camper here all round...except for this rain we're getting. Good for the crops I suppose! On YA's for ya replies and sense of humour!
FollowupID: 787458
