Anyone know? about rear seats (2nd row) 100 series
Submitted: Tuesday, Apr 23, 2013 at 13:47
Been-Everywhereman
I want to fit the passenger side rear split
seat FROM a 100 series GXL,,, INTO a 105 Series Standard Landcruiser so I can have a
seat for passengers in the second row on the left hand side and fridges on the right hand side behind the driver.
The standard rear
seat for a 105 is a bench and cannot be used as I wish.
My question to the Landcruiser experts is "are the floorpans of both vehicles identical with all the same mounting options so I can do this modification and interchange all the floor brackets and bolts between the 2 vehicles"?
Regards.
Reply By: Member - PJR (NSW) - Tuesday, Apr 23, 2013 at 14:04
I cannot answer you but have you tilted up the rear
seat to see if there are any unused indentations or mounts?
If it is possible are there any registration issues that may need to address.
I think that I would ask on lcool.org
here
509608
Reply By: pval - Thursday, Apr 25, 2013 at 20:45
Hi,I am in process of changing my seats to gxl.If you only want to put in passanger side smaller section
seat it should just fit and has 1 lock down point which is the existing one.The larger section
seat requires 2 lock down points,one is existing but you would need to change the other to a double lock down point.You will see blanked of
section on the floor when you lift vinyl flooring.
Paul
509782
