Caravan TV neoniQ LED 18.5
Submitted: Saturday, May 04, 2013 at 10:07
ThreadID: 102006 Views:3511 Replies:4 FollowUps:4
Hi I was wondering if any one has tried these in their Van's? They are cheap I know, but I was never going to put in a TV in but at this price I'm considering it.
http://www.oo.com.au/neoniQ-47cm-18-5-HD-LED-LCD_P132468C2.cfm?cm_sp=SubCatFilter-_-TestC-_-Product
Reply By: KenInPerth - Saturday, May 04, 2013 at 17:44
Hi Reef
I'll give you my humble opinion on stuff like this.
1. you will pretty much get what you pay for - so don't buy this and expect Sony quality.
2. electronics these days is fairly reliable in terms of failures, and I personally would probably take the risk and buy this if I did not want to spend a lot of money to use something once in a while.
3. unless it is DOA, consider it a throw away item and do your dough if something goes wrong as it will not be worth the aggarvation and cost trying to fix it or get it fixed under any warranty it has (which will probably be return to somehere in the East) unless you live where the warranty is handled. But at that price you are not losing much if you get some use out f it.
4. some of these "cheapies" like some of the mobile phone "cheapies" can have some performance issues but you have to be prepared to put up with that.
5. be aware that while it has a HD tuner, you will need to be in a digital reception area or have a satellite kit to get TV. And you will need some form of external antenna unless in a really strong reception area.
6. You will probably find a number of these units all come out of the same factory wth different brand names on them and they wll generally serve you well for a considerable period of time.
In all honesty I have had better reliability out of some cheap foreign stuff than Aus or US made stuff of more recent times.
Ken
AnswerID: 510311
Reply By: steved58 - Saturday, May 04, 2013 at 19:25
For an extra few $ buy a name brand good guys had a teac for $209 less for cash with built in dvd lg start at $168 they are 19volt acheap $20 power converter from ebay will run them on 12volt the teac is 12 volt have a look around It is much better with a local store if there is a problem
All the best steve
AnswerID: 510318
Reply By: Member - Peter M (QLD) - Sunday, May 05, 2013 at 08:35
Good morning all
We purchased a Neoni digital TV for our van about 2 years ago. We run it on 12 volt all of the time and it has been great,
Whereas we had major problems with the KNOWN brand that was supplied new with our van 4 years ago which only ran on 240 volt.
PeterM
AnswerID: 510347
Follow Up By: kev.h - Sunday, May 05, 2013 at 10:13
Try Kogan his add is at the bottom of the page payed $169 with DVD and 12v adapter works a treat have bought several things from him without problem
Kev
FollowupID: 788452
Follow Up By: kev.h - Sunday, May 05, 2013 at 10:14
Should have added 22"
Kev
FollowupID: 788453
Reply By: reef - Sunday, May 05, 2013 at 10:51
Cheers thanks guys. I will have a look at them. Also are you guys using an antenna or a dish?
AnswerID: 510359
Follow Up By: 08crd - Sunday, May 05, 2013 at 16:49
I bought the neon lcd t.v for the van, but found it unsuitable due to the glossy sceen causing reflections, making it hard to see the picture.
If possible go for a t.v with a matt finish screen, it is much easier to view. Well that's my opinion, for what it is worth.
FollowupID: 788475
Follow Up By: 08crd - Sunday, May 05, 2013 at 16:52
Should have said, I ended up giving the neon away and purchased a soniq with matt screen from J.B's.
From memory I think it was a similar price to the OO online price
FollowupID: 788477
