Replacing Torch Batteries
Submitted: Sunday, May 05, 2013 at 10:01
Priscilla G
I need to replace the batteries in a Led lenser P7 torch before we head off on holiday.Does anyone know where these batteries can be purchased from & do they have to be replaced with the same as originals( in brand name).
Reply By: Member - PJR (NSW) - Sunday, May 05, 2013 at 10:12
According to the description at
www.torpedo.com.au just replace them with 4 x AAA Batteries. But that is for the model advertised at that link.
Apparently there are several variants. Which one are you talking about?
510354
Follow Up By: Priscilla G - Sunday, May 05, 2013 at 10:19
The ones that are in the torch are Led Lenser AAA alkaline-ionic
788454
Follow Up By: Member - PJR (NSW) - Sunday, May 05, 2013 at 10:26
What model torch is it? Is there anything on it or the packing that said only use such and such batteries?
I cannot see why not just three alkaline ones from the
supermarket.
But to be safe search for the torch and read it's specifications.
788455
Follow Up By: olcoolone - Sunday, May 05, 2013 at 10:43
There is only one LED Lenser P7 and it takes 4 X AAA.
788458
Follow Up By: Member - PJR (NSW) - Sunday, May 05, 2013 at 10:55
There you go Priscilla
788460
Follow Up By: Batt's - Monday, May 13, 2013 at 07:22
I use energizer AA and AAA recharble batteries in A/C & TV remotes tourches XBox controlers and camera's they have a larger storage capacity than normal batteries lasting 2 to 3 times longer. The charger is 240v with a 12v adaptor for the car which we take on holidays and always have a few spare batteries on hand.
789049
Reply By: olcoolone - Sunday, May 05, 2013 at 10:39
Batteries are batteries and brand name has little to do with it, we just use standard Duracell alkalines...... cheap, readily available and they work.
Any good alkaline battery will do.
You could by the LED Lenser one and pay a price for no advantage.
510357
Reply By: Sand Man (SA) - Sunday, May 05, 2013 at 10:53
Hi Pricilla,
The P7 accepts 4 x standard AAA batteries available from any
supermarket.
Alkaline batteries are best for longer life.
I use Energizer Max AAA batteries but other brands (eg Duracell) will also be OK.
510360
Follow Up By: Priscilla G - Sunday, May 05, 2013 at 11:02
Thank you all for you info. Makes it easy to do !
788463
Reply By: Member - evaredy - Sunday, May 05, 2013 at 11:51
I have the same torch and I just use rechargeables, but any AAA will do.
510363
Reply By: kennchris - Sunday, May 05, 2013 at 19:43
We have two Led Lenser torches and haven,t found any batteries that last as long as the ones that came with the torches when we brought them.
510383
Follow Up By: Penchy - Monday, May 06, 2013 at 15:38
I think someone else should post a comment that any batteries are fine. I'm not sure if this point has been made clear enough yet.
788526
Reply By: kennchris - Monday, May 06, 2013 at 17:53
That's right any batteries will do the same job but we haven't found any that last as long as the led lensers and we have tried a fair few and they aren't the cheap ones and that's as far as it goes with Led Lenser, we have two of there torches.
510469
Reply By: Member - J&R - Wednesday, May 08, 2013 at 10:39
Only use LL batteries.
The torch will not work with anything but, will self destruct 30 seconds after installing 'other brand' batteries, will transmit a coded alien signal to a cloaked mothership in orbit telling it it has been violated, and may even teleport the holder of the torch to the anal probing department for additional conditioning.
510572
