cargo barrier and water storage
Submitted: Sunday, May 19, 2013 at 21:12
locked hilux
have question see ing products out there but has any one seen a cargo barrier that goes in the back
seat if you have stuff there?? and what is the best way to carry
water have seen few poly tanks are they any good and has anyone fitted one to a dual cab hilux?? need place for
water and containers dont taste that great bladers leak and all are usualy only 10l or 20l is there bigger for more storage??
Reply By: Member - Lisa M (NSW) - Sunday, May 19, 2013 at 21:31
We have a
water bladder hanging behind the rear
seat in our dual cab hilux, we drain it after each trip and use a solution to keep the
water tasting nice. No problems with leaking,
water tastes fine, it holds 50 litres. I bought it through the local ARB store.
511415
Follow Up By: Member - Drew W (VIC) - Monday, May 20, 2013 at 11:24
Hi I purchased a barrier manufactured by from an Autosport store for my Hilux that does just what you need without too much hassle. Just make sure you select the right size when purchasing.
789684
Follow Up By: Member - Drew W (VIC) - Monday, May 20, 2013 at 11:27
Sorry ,the manufacturer was Boab look at boabstorage.com.au
789685
Reply By: Member - John and Val - Sunday, May 19, 2013 at 21:46
From our experience, its not a bad idea, especially in remote areas, to carry
water in multiple containers. The quality of
water that you can get will vary a lot. If you have one big container you then may have to put poor quality
water in it if that is all that is available. For years we have carried a couple of 20 litre containers of good quality
water that are a reserve supply, but for day to day use we use 10 X 3l juice bottles. That way good
water is not spoilt by less good
water, and if we have the small bottles full of poor quality
water its easy to tip it out and refill them when better stuff is available. Works for us.
Val
| J and V
- Albert Einstein
511418
Follow Up By: Members Pa & Ma. - Monday, May 20, 2013 at 13:33
Hi, We do the same as John & Val for the cooking &
drinking water.
We write on the bottles when we fill them.
Take care, safe travels ma.
789692
Follow Up By: Member - PJR (NSW) - Monday, May 20, 2013 at 14:56
Similar here.
Up until today we had two ways of carrying
water. 55 liters in a dual fuel/
water long range
tank under the car and some in 10lt white plastic
water container/s in back of car.
Last friday we picked up a dual carrier Kaymar rear bar with a spare wheel carrier on the laft and a jerry can carrier on the right. We can now have another two jerry cans on the back for longer trips as needed.
789705
Reply By: Member - eighty matey - Sunday, May 19, 2013 at 21:47
I know with the wagons you can get a cargo barrier that fits behind the front seats.
We got a 60 litre bladder made up to our specifications. It works really
well. We use it for our secondary
water supply and have 45 litre stainless
tank for our main
drinking water.
Steve
511419
Reply By: Member - John - Monday, May 20, 2013 at 06:01
Flexi
Tank do one, follow the link.
Hilux bladder
511429
Follow Up By: Member - Lisa M (NSW) - Monday, May 20, 2013 at 08:40
Yep, that's the one we have. We also have a
tank in the camper, and on outback trips take some smaller containers as
well. It's a good point above about not risking contaminating your main
water supply.
789666
Follow Up By: landseka - Monday, May 20, 2013 at 12:13
....also if you spring a leak you won't lose the lot.
789687
