Wednesday, Feb 04, 2004 at 17:17
Hi Roachie,
Thanks for the note mate.
Well I am not farmiliar with the GU setup but the same plastic plate you refer to is metal on GQ's,
Well Just an update if you read about my attempts to find the heating problems in GQ's....I am oNLy refering to my GQ ok as i cant speak for other cars as everyone does different things.
But i have found some very interesting things indeed. I have NOT installed the oil cooler yet, I am very involved in finding a cure for overheating first before just ADDING things on. Starting off with dasics rather than spending dollars.
I must point out that my GQ has a 4 core radiator fitted.
First thing i did was pull out radiator and give it a good pressure clean, Also cleaned condenser while i was there, Pressure flushed cooling system and got some coolant. I replaced bottom hose with one with an internal spring as it felt a bit too soft for my liking. With all the basics done, We noticed a definate drop in general driving around temperatures ( thats heading down to Bulli).
I have run many proper tests as far as temperature goes while fully loaded and on roads of all kind of terrain, But most tests have been done on hot days. I "borrowed" a Temperature unit which had hoses and stuff running outside the body , taped to it to stop flapping...anyway i think you know what i mean.
Well this thing was amazing.
SO here is what i have done so far, mind you...I am not in the "modifying " stage as i want to see any differences in temp while removing things off the car.
I found that :
by removing the Nissan Nudge bar with the 2 IPF's, temp dropped by 3 degrees (doing the same
hill repeatedly) I am refering to bulli pass as its quite a test for the old girl.
The NISSAN badge sitting in the middle of the grill also restricted air flow, not much, but im trying to get this thing as cool as i can.
My next step was to remove the grill totally off the front of the car, by doing this, temp went up 2%, I thought it would drop but i now know that the actual ribs between the grill housing really work air flow towards the center of radiator. Very similar to that of a planes wing, but on a much smaller scale.
That ended the day, headed home and had more ideas already planned, I have since made up a cowl that bolts down to the car panel at front of radiator, this cover comes out moulded to the demensions of the ctr grill frame where the ribs are. It acts like a funnel, once the air hits the grill ribs, it cannot escape, so it has to pass through the radiator, We went back down to Bulli to give it 3 runs, the difference was amazing, Different day yes, but still a hot one. Anyway temp dropped by 6 degrees. Now from the Bulli climbs ive done before even thinking of these changes to the last day there, my gauge has dropped from just over 3/4 to just on 1/2.
My next try will involve adding angled fins to this cover i made up, Hoping it will swirl the air kinda like a donaldson pre filter setup. I beileve (yet to prove) that if i can get the air to swirl while under pressure it should pump more air through.
For those of you that dont understand what im trying to say here...its just like filling a bottle up with
water, tuning it upside down and watching the
water spill out, the air comming back in to the bottle causes the outgoing
water to slow down. BUT if u were to make that
water inside the bottle swirl as it comes out, you will find that it comes out much quicker and thus allowing more volume to pass in a shorter time.
Now guys, please dont dig into me on this ok, i am no scientist, its just trial and error stuff i am playing with, but so far, I have dropped the temp on my GQ to the point that i am no longer affraid of overheating. This is all taking a long time to get through and the cost of
fuel etc is fairly high plus ware and tear on both me and car. But if I can do this without buying a 1200 dollar radiator and stuff, then why not if it can help others out there, I dont mind at all.
Just remember...this is MY car im refering to, I cant speak for others or what reaction they would have from this, but i drive MY car and thats all that matters to me.
I will let you know how stage 2 goes when i get round to doing it.
Regards AngeloI love it when you talk DIRTY !
45449
Follow Up By: Roachie - Wednesday, Feb 04, 2004 at 17:36
Thanks for the comprehensive report Angelo. You sure are leaving no stone unturned in your attempts to beat the issue (note I refuse to call it a "problem"). Just another thought for you to consider.....I know a bloke in
Sydney who is a tour operator; known as "DB"; Dave Bradley. He operates an arm of Vic Widman's Great Divide Tours and calls it "Platinum Tours". He is currently running a GU 4.2T/D and Ultimate Camper (same set up as me). He was featured in 4WD Monthly a few months ago.
Well before he had the GU, he had a severely worked over and loaded GQ 4.2 with Safari Intercooled Turbo. He cured his overheating problem by adding a GU bonnet scoop. He placed it centrally on the bonnet, just behind the radiator, mounted backwards. That vehicle has also been featured in 4WD MOnthly mag a year or 2 ago. If you like I can find out what issue and let you know through the
forum.
Also, bear in mind that because the GQ's radiator is not as wide as the GU, the ones made by PWR might not be as expensive as the GU model; assuming they actually make a GQ replacement of course
Roachie
307549
Follow Up By: Mark - Wednesday, Feb 04, 2004 at 18:39
Hi Cokeaddict, I like your method of proving whether your changes actually work, MUCH more accurate than using the vehicle gauge and quite a scientific approach.
But I am not sure that your vortex (swirling) idea is technically correct. As an example, we had a situationat work where we had a
tank of
water being filled from the a pipe mounted on the side and being emptied by a pipe at the bottom in the middle (
tank on a stand).
Because the feed pipe was entering on the side, the
tank had a large vortex (swirling motion). This swirling motion extended down the outlet pipe in the base of the
tank. The most
water that we could get from the outlet pipe was 200 l/min, with the rest of the feed
water overflowing the
tank. I then installed a vortex breaker that stopped the swirling motion (a simple X in the bottom of the
tank). All other factors remained constant. Maximum outlet flow is now over 400 l/min and the
tank no longer overflows. The outlet pipe is now a solid flow of
water, not swirling
water with an inner air core.
As for the Donaldson example, the reason for swirling the air is to try and get any dirt flung to the outside by centrifigul force and have the dirt collected in the outer container. Note that most
snorkel manufacturers do NOT recommend donalson type cleaners on turbo diesels as they restict the air flow.
I am not trying to knock your idea, but my engineering background says the theory is wrong. It may end up being a lot of effort for something that has the opposite effect. I think your funnel analogy is correct and that by simply adding sides to the grille onto the bullbar to act as a larger "mouth" will force more air into the radiator.
Look foward to hearing about your future experiments.
Mark
2003 GU 3.0TD
307554
Follow Up By: Brett - Wednesday, Feb 04, 2004 at 19:49
I remember reading years ago thet the TOYOTA badge on the front of the early model 75 series caused a reduction in air-flow to the radiator by either 13 or 17%....amazing isn't it?
307557
