Landcrusier Fuses
Submitted: Sunday, Jul 28, 2013 at 18:16
ThreadID: 103447 Views:2459 Replies:4 FollowUps:5
Hey,Can anyone help with the location of the fuse for the reversing lights on a 2011 cab chassis?
Reply By: Member - Des Lexic - Sunday, Jul 28, 2013 at 18:38
My vehicle is different from yours but I have another fuse location in the side panel by my right foot. There is a knob to unscrew adjacent the accelerator pedal.
AnswerID: 515499
Reply By: Member - Stuart P (WA) - Sunday, Jul 28, 2013 at 19:07
there is a fuse box on the passenger side foot well, another under the bonnet
AnswerID: 515500
Reply By: olcoolone - Sunday, Jul 28, 2013 at 21:52
Fuse 42 for the windscreen wipers, right hand kick panel.
AnswerID: 515510
Follow Up By: Narrabrisparky - Monday, Jul 29, 2013 at 18:33
My wipers still work, but indicators and fan dont.
This all came about by putting in an led lamp in the reversing light
FollowupID: 794847
Reply By: Member - Geoff M (VIC) - Monday, Jul 29, 2013 at 19:43
Looking at the workshop manual, the reverse wiring circuit (or "backup circuit" as it is called in the manual) shows a 15amp fuse but its a bit unclear where this fuse is located.
A bit more digging and the junction connector (J35) for the reverse switch is on the passenger side just above the fuse panel so I assume that the fuse will be below. I looked at my fuse panels (I have a 2012 cab chassis) but it's not very clear on the fuse descriptions so I can see your problem.
I tried to add a copy of the wiring diagram but are having some problems and unfortunately have run out of time - I can try again tomorrow if you like.
Cheers, Geoff
AnswerID: 515561
Follow Up By: Member - Geoff M (VIC) - Tuesday, Jul 30, 2013 at 10:08
Here is the wiring diagram:
FollowupID: 794874
Follow Up By: Narrabrisparky - Tuesday, Jul 30, 2013 at 18:41
Thanks Geoff. I'll let you know how I go.
FollowupID: 794905
Follow Up By: Member - Geoff M (VIC) - Tuesday, Jul 30, 2013 at 18:51
No worries and good luck!
I'd be checking the fuses in the passenger side fuse box, particularly the couple of 15A fuses.
Cheers, Geoff
FollowupID: 794906
Follow Up By: Narrabrisparky - Wednesday, Jul 31, 2013 at 17:41
I found a 15a fuse open circuit but not indicating blown. Found when checking all fuses with meter.
Quite surprised 1 x 15amp fuse supplies indicators, fan and reversinf lights.
Thanks for help from All.
FollowupID: 794967
