Thetford Toilet
Submitted: Thursday, Aug 08, 2013 at 10:24
ThreadID: 103669 Views:2467 Replies:4 FollowUps:2
Hi, Does anyone know how to remove a Thetford C3 ? It may be that the pump has stopped working but still need to know how to access the workings. Bill
Reply By: Member - Alan H (QLD) - Thursday, Aug 08, 2013 at 12:11
thetford repairs
Go to the above link and download the "Repair instruction for sanitation products"
AnswerID: 516083
Follow Up By: Member - bill f (QLD) - Thursday, Aug 08, 2013 at 17:48
Thanks for that link Alan. Now to relate the photos to the van. Thanks again Bill
FollowupID: 795390
Reply By: Ross M - Thursday, Aug 08, 2013 at 19:34
bill f
I didn't know that Thetford called their system a C3.
Better than No. 1's or No.2's I suppose.
Ross M
AnswerID: 516103
Reply By: Bobjl - Thursday, Aug 08, 2013 at 23:30
Bill
For what it is worth just recently my Thetford Cassette loo stopped pumping water to flush. The issue was the fuse which is situated at the back of the cavity where the cassette sits. Some moisture had built up causing corrosion and a poor connection, all I had to do was give the fuse blades a rub with emery and it solved the problem.
AnswerID: 516110
Follow Up By: Member - bill f (QLD) - Friday, Aug 09, 2013 at 00:42
Bob,
Sounds the same as mine. Will look in the morning. Hope that is all it is. Thanks Bill
FollowupID: 795409
Reply By: Member - Alan H (QLD) - Friday, Aug 09, 2013 at 08:18
Mine is a 402 but it stopped flushing a while ago. Fuse was gone but the pump was seized. Removed pump (with much difficulty) and sprayed with WD40 and freed the impeller.
Reinstalled the pump and new fuse and now all works OK
Trust you find your problem
AnswerID: 516122
