200 series landcruiser trip computer
Submitted: Monday, Aug 19, 2013 at 19:45
Steve R11
Hi guys, I've just picked up a new Altitude & was wondering if there's any way to upgrade the trip computer to include
fuel consumption & klm left
Reply By: Member - Phil G (SA) - Monday, Aug 19, 2013 at 19:49
Yep, Just buy a Scangauge II.
About $160 and plugs simply into the diagnostic port under the dash. The gauge is mounted with Velcro on the steering column or dash. As
well as all the
fuel consumption stats I use it to measure coolant temp, transmission temp, voltage, air intake temp, boost, etc etc
516730
Follow Up By: Steve R11 - Monday, Aug 19, 2013 at 20:03
Thanks Phil G I'll certainly look into that option. Do you know if there's any upgrade for the current to the existing computer to match the VX?
796132
Follow Up By: Member - Phil G (SA) - Monday, Aug 19, 2013 at 21:51
Steve,
I've not heard of anyone upgrading to the VX/Sahara dash. I doubt it would be feasible. Scangauge tells you a lot more info than you'd get anyway with a VX.
Ours is an Altitude as
well. Looks like they re-released it because it was popular.
796152
Reply By: olcoolone - Tuesday, Aug 20, 2013 at 08:41
You can do anything but it comes down to value for money and I don't think a dash upgrade would be cheap.
I haven't heard anyone doing it as yet, try the Lcool
forum under 200 series.
516755
Follow Up By: Steve R11 - Tuesday, Aug 20, 2013 at 20:29
Thanks olcoolone I'll check that out
796287
Reply By: cruza25 - Tuesday, Aug 20, 2013 at 20:08
Not sure if it's as good as a scangauge but if you buy an obd2 blue tooth unit $12 on eBay and down load torque pro app to android phone . This will read and do many functions from the obd port info..
Will also read and reset all fault codes which can help diagnose problems.
Mike
516811
