Thursday, Aug 29, 2013 at 12:43
Have you needed your winch? How often? How often do you find yourself in need with no one else around who has a winch and could help you?
Is one time of need enough to make it worth always having a winch?
In answer to the original question:
I had a warn winch fitted to a steel bar on my JK Jeep I owned previously, we did 130,000klms all over Oz in 5 years and used it 5 times, every one of those occasions was for others benefits.
One occasion I was happily camped near
Streaky Bay and a fellow strolled up to me and asked if I could come and help him and his mates out with my winch. Drove a few ks down
the beach to find four fellows standing looking into the surf, turns out they had tied a rope to their boat trailer with tinny on board to let it out into the
water (by hand) and all of a sudden the trailer sank when it went “over the ledge” Their Rav 4 didn’t cut the mustard, the Jeep and its winch had it all out in ten minutes and a slab was earnt.
Three of the other occasions were in Tasmania on wet slippery tracks when we came across others bogged or on one occasion precariously slipped of a track where anything but the slow precise pull of a winch would have seen the Toyota Hilux rolling down into the river.
The final occasion was on the
Simpson Desert, my friends LC200 slipped sideways into a washout pushing one side of his twin wheel carrier against the other, not allowing him to open the back of the cruiser without a lot of grunting and swearing. We used shovels to alter the washout and drove out but later in
camp we set the Jeep up at 90 degrees to the LC and winched the steel away from each other just a smidgen, all fixed.
After installing the steel bar and winch in the early times of ownership it was noted it cost us at least 1.5 ltrs/100 klms and when we added the lift and bigger tyres we “lost” another 1.5 ltrs/100klms. At close to standard we saw just under 10ltrs/100 klms often but after “mods” we hardly ever saw under 13.5 ltrs/100 klms. 130klms at an extra 3.5 litres per klm was a high price to pay.
We have changed our touring chariot now to a new PX
Ranger, we chose to lift it 50mm at the front and 100mm at the back (to accommodate our slide on camper) and just change tyres to All Terrains on the standard rims. We have fitted a smart bar, good recovery hooks front and back, carry 4 max tracks and good recovery gear including a long handled shovel, (but no winch) and 30,000 klms to date including another trip to Tasmania and a trip down the
Canning Stock route has returned overall fuel use at 11ltrs/100 klms (with highway
miles at
well under 9 ltrs/100 klms).
Basically as we are getting older (and wiser) we chooses where we go to suit the vehicle set up and off course the
Ranger does not look as rough and ready as the Jeep did so we are not asked to help others as often. The difference in fuel use and the extra comfort of the vehicle set up is allowing us to do more kilometres out in our great “bush”.
PS to all the Nay Sayers re the plastic smart bar….. do some research, read some reports. We haven’t hit anything yet (and we only hit one bird in the 5 years with the previous Jeeps steel bar), we pull over at dusk and boil the billy on the rare occasion we are not yet camped at that scary, dangerous time on the road. We also wait around our breakfast campfire until the early morning road is clear of animals (and fog in Tasmania). The smart bar added 30 kilos to the front of the
Ranger including the two lights and didn’t necessitate an extra beefy front spring replacement as it didn’t drop the front any perceivable amount when installed. Its also much more aerodynamic (I think ) and does not seem to change the fuel use at all. My research showed that if we do hit a reasonably large fury animal the smart bar will fair just as
well if not better than any other bar, yes even a steel one. I hope to never test this and in the mean time I will use the dollars saved to fuel up and go out and see more.
Steve and Carol
517255
Follow Up By: redgp - Thursday, Aug 29, 2013 at 13:15
a great link, Landy.
In defence of adding lights to our Smart bar, we did at first, install the bar with no lights but the Standard lights on the
Ranger are useless for any highway speed anywhere near 110klms/hour. We hardly ever travel at night but we did have one occasion to "go out" one night, when
camping near
Esperance , to go to diner at a restaurant, and it seems the smart bar shielded some of the factory lights and made it even worse so for the rare occasion we need them we installed a set of (reasonably cheap, good quality KC Daylighters) lights, one spread beam, one spot beam.
Also in The link Landy provided it mentions diff locks, we had them fitted in the Jeep but found the clever electronics in the modern 4x4 are better in almost every instance and whenever I tried using the front diff lock in the Jeep it just took away my steering control almost always leaving me in a worse pickle.
I have used the rear diff lock in the
Ranger (standard in the XLT model we have) just to make sure I know what it feels like and what it does and how the vehicle reacts. On some rather rough stuff on the
Canning Stock Route, Low range in drive (auto) with diff lock engaged (rear) we climbed some gnarly rock shelves and with the lift we have (and no overhanging tow bar we got through with not even a scratch to the underbelly.
The clever electronic gadgetry on the
Ranger, leaving it in drive in high range (auto) got us through everything else we encountered including four days of heavy rain and
water on the tracks for 100s of meters at a time.
Steve and Carol
796881
Follow Up By: Member - OzBadDude - Thursday, Aug 29, 2013 at 17:10
I must say regdp, that your experience of fuel consumption before and after upgrades is quite sobering!
796905
