Towbar to suit Surf KZN185 (Import) Prado will fit but what is rating ?
Submitted: Tuesday, Feb 10, 2004 at 17:39
ThreadID: 10425 Views:4347 Replies:3 FollowUps:1
Believe a Prado Towbar will fit the KZN185's but the cross brace at the rear is missing on the Surf's as compared to the Prado's. Result is that the Prado towbars will fit - but the rear mounting bolts will not be able to be fixed (no rear cross brace) - does anyone know what tow rating this would result in ?
Also anyone recommend a bar ?
Would also like a bar that does not take away too much of the departure angle.
Cheers, Beddo
Surf KZN185
<- Yengo NP, Central Coast NSW
Reply By: Truckster (Vic) - Tuesday, Feb 10, 2004 at 20:28
surely someone makes one for the surf by now?
AnswerID: 46201
Reply By: donk - Tuesday, Feb 10, 2004 at 21:42
I didn't think that genuine towbars on 90 series Prado's had mounting bolts that went in to the rear crossmember
I thought the only had three ?????? mounting bolts in to each chassis rail (one of which had to be drilled through the chassis
Could be wrong, it has been a while since i fitted one of these
Regards Don
AnswerID: 46232
Follow Up By: Jeff (Beddo) - Wednesday, Feb 11, 2004 at 09:25
I'll check it out today but that is what I have been led to believe.Cheers, Beddo
Surf KZN185
FollowupID: 308181
Reply By: towbar - Thursday, Feb 12, 2004 at 10:40
hayman reese is the only answer .Part no R1492 fits fine as for tow rating call the rta .
thanks
AnswerID: 46440
