Maxtrax shovel and awning brackets
Submitted: Thursday, Sep 19, 2013 at 17:25
ThreadID: 104394 Views:5617 Replies:7 FollowUps:2
This is one for the budding engineers out there, I have a 150 prado with the roof rails, I have a set of 2 Thule roof racks on top. I want to make up a couple of brackets, on passenger side to mount an awning which is 2.5m long. On the other side I would like to make the same to take a set of maxtrax and a shovel. The thing is I would like all of the brackets to be, as such, quick release and removable. But when fitted with the gear stowed, be able to lock all in place. I just want to be able to fit it all when going away, and remove it all,when doing the commute thing.. I would have got a full rack, but think this way may be easier, without the constant wind drag.. Any ideas would be a big help. Thanks. Odog
Reply By: Bob Y. - Qld - Thursday, Sep 19, 2013 at 21:45
Odog,
Perhaps some RHS, one size sleeving into bigger size, and locked together by a Shaft Lock Pin(available from Ovesco). The bigger size RHS could bolt to your Thule racks?
You'd need to weld a bracket on end of removable pieces, to mount the awning/Maxtrax holders. Aluminium would be the go, lightweight, but need a mig to weld it.
Bob.
AnswerID: 518452
Reply By: Phil B (WA) - Friday, Sep 20, 2013 at 09:09
Hi Odog
Check out the Quick Fist range at Dolium- all sorts of goodies there.
AnswerID: 518480
Follow Up By: Phil B (WA) - Friday, Sep 20, 2013 at 09:10
Sorry link didn't come up - see below
Quick Fist
FollowupID: 798331
Reply By: Bludge - Friday, Sep 20, 2013 at 11:53
Rhino have a mass of items that would do as you ask, I do not know if they will fit your Thule system.
TryRhino roof rack accessories
AnswerID: 518489
Reply By: Odog - Friday, Sep 20, 2013 at 19:20
Thanks guys, ill see what I come up with, need to think about it and figure out what will suit my needs, had a look on another site, saw talk about maxrax? I'll just play n see. Cheers. Odog
AnswerID: 518511
Reply By: Member - Andrew L (WA) - Friday, Sep 20, 2013 at 21:27
Here you go. There is a guy on Pradopoint that makes and sells mounting brackets for Maxtrax:TraxRax
AnswerID: 518515
Follow Up By: Odog - Friday, Sep 20, 2013 at 21:39
Thanks Andrew, read about them, but couldn't find any more info. Cheers
FollowupID: 798387
Reply By: The Bantam - Sunday, Sep 22, 2013 at 16:46
The concern I have is....are those roof rails strong enough for what you are looking at doing.
I know the maxtrax are pretty light, but an 8 foot awning on roof rails sounds a bit sus to me.
that 8 foot awning can produce quite a bit of leverage.
They realy are not expecting you to carry much on the roof of most of these modern SUV style 4wds.
AnswerID: 518597
Reply By: Member - Michael A (ACT) - Monday, Sep 23, 2013 at 19:59
try traxrax look up on FB. Made by a private individual on another forum.
PS They may be similar to wot you need
M
AnswerID: 518659
