Waeco cdf-25 fridge
Submitted: Saturday, Nov 02, 2013 at 11:43
cobes
Hi there,
I would like to know if this model waeco uses the chinese compressor or the Danfoss?
Also any first hand comments on this fridge would be greatly appreciated weather they be good or bad. looking to buy one second hand and thought they may have used the danfoss compressor in the earlier days.
Chris.
Reply By: AlbyNSW - Saturday, Nov 02, 2013 at 12:00
Pretty sure you will find it is the Chinese compressor, will still operate at the same temps but they are not as efficient power wise as the Danfoss
520750
Reply By: Andrew D. - Saturday, Nov 02, 2013 at 13:56
The Chinese compressor which is usually a Wanbao or Domus are equally as good as the Secop/Danfoss. The Wanbao would be the pick of all low voltage compressors in the hobby end of the market.
Don't listen to any rubbish they are not as efficient as it is not factual.
Engel, Secop/Danfoss, Wanbao and Domus all equal in the power consumption v cooling stakes. The Engel runs for considerably more time compared to the Secop/Danfoss and Domus. Wanbao is larger than BD35F in capacity and has higher amperage and runs for less time. Most efficient low voltage compressor is Mitsubishi. Not easily available in Australia and expensive as swash plate type compressor.
520754
Follow Up By: AlbyNSW - Saturday, Nov 02, 2013 at 20:30
Andrew my response above with regard to efficiency is repeating what the technical department told me at Waeco when I enquired, 12 months ago.
Perhaps the inefficiency is related to the cabinet and insulation design not the compressor ??
801277
Reply By: Road Warrior - Sunday, Nov 03, 2013 at 22:22
I have a CDF35 Waeco with the Chinese compressor and its a great little unit. Power consumption on average I have worked out to about 3.5a/hr
520811
Follow Up By: Member - Barry H (WA) - Monday, Nov 04, 2013 at 18:40
Road Warrior,
I have a Waeco CDF35 (use it as a freezer) has a Danfoss compressor,works a treat, have just come back (Sunday) from a 8 day trip to
Stokes Inlet, never missed a beat, current draw was about 2.5 ah.
Barry H
801412
