Tyredog settings
Submitted: Wednesday, Nov 06, 2013 at 11:39
sastra
I have received a Tyredog TD1000A-X with four sensors and it appears the pressure and temp settings cannot be set for individual tyres. Settings apply to all four. Have read the manual many times.
Is this correct?
Reply By: Robin Miller - Wednesday, Nov 06, 2013 at 15:59
Thats correct Sastra - also the temp readings are a waste of time - but despite this they are useful accessory
520955
Reply By: olcoolone - Wednesday, Nov 06, 2013 at 18:39
Set the tyre pressure on the TPMS to the lowest pressure in the tyres, you will have no problems and it will still warn you of a leak.
520970
Reply By: Mikee5 - Wednesday, Nov 06, 2013 at 19:01
My Tyredog (model unknown) for 6 sensors, allows me to set each axle for different temp and pressure. The manual is not good but keep exploring the on screen menu.
520973
Follow Up By: Member - Terry W4 - Wednesday, Nov 06, 2013 at 19:10
Also my Tyredog (6 points - 4 car and 2 trailer) allows individual or set settings for all.
I am happy with set settings for all.
801574
Reply By: Member - Tony Z (NSW) - Thursday, Nov 07, 2013 at 14:13
Gday sastra I have Tyredog model TD-2300A-X Series set of 6 and you can set individual press. and temps for each wheel. But am having to reset unit every time you start the car as it turns it's self off !?
521032
Reply By: Member - Bentaxle - Thursday, Nov 07, 2013 at 19:52
Sastra
I have a Tyredog TD - 2000A Series with 6 wheel sensors, these allow me to set and adjust each one individually and once set do not require resetting, no matter how many times vehicle is restarted. unless you are changing parameters . The big downside is the cost if an individual sensor needs replacing ~$90.00ea.
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
521054
