TAINTED WATER
Submitted: Friday, Nov 08, 2013 at 19:41
troopy 47
I have 80 litre RV
water fitted under my tray with filler pipe to side of canopy and 10 mm food
water grade hose to tap and the
water has bad taste of plastic I have tried
Milton's baby bottle wash and bi carb soda mix but still no good any suggestions would be great.
Reply By: Allan B (Member, SunCoast) - Friday, Nov 08, 2013 at 21:58
I found
Tank Cleen from BCF worked
well for my new poly tanks.
Probably available elsewhere also.
521148
Reply By: KevinE - Saturday, Nov 09, 2013 at 08:15
What brand are the components troopy?
If you fit "Pope" brand
water grade hose you'll never get rid of that horrible plastic taste! You'll have to replace it.
Others may have similar info on other components?
Kevin....... :=)
521154
Reply By: tazbaz - Saturday, Nov 09, 2013 at 10:09
Troopy
Had the same problem. Replaced hose, flushed out
tank. Fixed.
521159
Reply By: Member - Phil G (SA) - Saturday, Nov 09, 2013 at 20:14
On the undertray
tank on my last vehicle I'd get a plastic taste for the first 500mls - then it would go away if I kept running the
water - so I knew it was the hose and not the
tank. If you get the same, then replace the hose. AS above with Kevin, do not buy Pope brand
water hose. The Nylex and Neta brands are OK.
521192
Follow Up By: troopy 47 - Sunday, Nov 10, 2013 at 06:33
Just replaced all the hoses with non toxic
drinking water hose from RV
shop and have filled
tank with mix of bi carb soda and white vinegar and then filled
tank with clean
water leave it for 24 hours flush
tank out and hope it is OK.
801866
Reply By: LIFE MEMBER-snailbait - Thursday, Nov 14, 2013 at 16:29
troopy 47
if you fill up your
water tank with garden hose from town
water the chlorine burns the inside of the hose you must change all your hose to the blue double lined hose and no more tast
if you fill up from a rain
water tank it does not mater what hase you use
Terry
521449
