Cb radio
Submitted: Sunday, Nov 10, 2013 at 13:00
ThreadID: 105071 Views:2673 Replies:6 FollowUps:0
Hi all
My wife are doing a trip up thru the centre in our van IE the flinders ranges Alice the Rock and Darwin and was interested in purchasing the below CB and was interested in options from any one who has one or otherwise
GME TX3100 Plug&Play 80 channel CB
THANKS
Greg&Leonie
Reply By: MEMBER - Darian, SA - Sunday, Nov 10, 2013 at 13:18
Recently discussed Greg......have a look at post 104976.
AnswerID: 521214
Reply By: Member - blackbird1937 - Sunday, Nov 10, 2013 at 14:21
Hi Greg, I do not know if they are still available but I have a TX 6000 that I have used for approx 10 years. It has a fixed base but the radio can be taken out connect a small antenna and carried even if a little heavy. The radio was adjusted to 80 channels when I purchased it. We have been in the Flinders for 8 days, driven 1300 kms and still have not seen everything!
AnswerID: 521218
Reply By: Rob d b. - Sunday, Nov 10, 2013 at 14:30
Good enough radio. But if you can afford it purchase a better quality Ariel set up.
AnswerID: 521219
Reply By: Member - Stephen L (Clare SA) - Sunday, Nov 10, 2013 at 19:05
Hi Greg
The TX3100 is a good Australian made UHF Radio with 3 years warranty. Like I tell customers, regardless of what radio you buy, they all will have the same 5w output and the type of antenna that you buy will be the most important factor in the performance of the radio.
Cheers.
AnswerID: 521226
Reply By: AlbyNSW - Monday, Nov 11, 2013 at 17:43
I have one of those head units and are happy with it, the internal speaker is a bit tinny sounding so I bought an extension speaker that just plugs in and much better
I am running a different ariel to the one in the package but I have no reason to think it wouldn't be ok
Would happily purchase a 3100 again
AnswerID: 521271
Reply By: get outmore - Tuesday, Nov 12, 2013 at 00:15
Handy if in a convoy otherwise the uhf is my most least used equipment
Unless you have a specific use its a discretion ry spend
AnswerID: 521279
