Napisan powder or Liquid
Submitted: Tuesday, Nov 12, 2013 at 07:48
nootsa200873
Hi all. I have found some really useful info on portable
toilets here on the
forum. Now my next question is what do I use in the bottom
tank in regards to napisan? Powder or liquid and how much added to a litre of
water?
Thanks Chris.
Reply By: Griff61 - Tuesday, Nov 12, 2013 at 08:27
I put 2 caps off powdered napisan ( use the cheaper brand ie: Black & Gold or Home Brand) with about 1Ltr
water. Make sure you use white
toilet paper with no colour. Then you will have a stink free
toilet.
521285
Follow Up By: Andrew D. - Tuesday, Nov 12, 2013 at 14:27
Black & Gold is no good as doesn't have sufficient active ingredient. Aldi is the same only half active ingredient compared to Coles and Woolies for same price. Need to buy at Coles or Woolies Home Brand.
Good squirt of dish washing liquid in cassette and top
tank make substantial difference to breaking down and keeping top
tank, bowl and bottom
tank clean. Quick flush with
water with detergent gives bowl lining.
801995
Follow Up By: Griff61 - Tuesday, Nov 12, 2013 at 15:51
I agree look at Mother Hens article. Andrew back & gold is ok when you cant get anything else. We found just using white
toilet paper works also keeping the smell down. The dyes in the paper makes them smell also.
802001
Reply By: Member - John and Val - Tuesday, Nov 12, 2013 at 08:32
Motherhen has done an excellent blog on this. have a look
here.
From our recent experience a cheap Napisan equivalent and soft white
toilet paper works very
Val
| J and V
- Albert Einstein
521286
Reply By: Member - John and Lynne - Tuesday, Nov 12, 2013 at 08:35
The No Brand Nappy or Laundry Soaker from the supermarkets is cheap and works perfectly. The key ingredient for you is Sodium Percarbonate and it should be around 34%.
This information is often hidden in very small print somewhere on the label!
I have only ever seen it in powder form.
Just thoroughly rinse your cassette then put it back into the
toilet. Open the slide.
Get about a litre of warm
water in a jug. Sprinkle two lidsful of the Soaker into the cassette and pour in the
water.
Close slide.
Toilet is now ready to use.
You will need to empty the cassette about every fourth day.
There is no need to put anything in the top
tank. Other additives may interfere with the Soaker's effectiveness.
Apart from being more effective than the smelly chemicals
toilet manufacturers sell this Soaker is environmentally safe. Lynne
521287
Follow Up By: Andrew D. - Tuesday, Nov 12, 2013 at 14:30
"Get about a litre of warm
water."
Only need to mix in TEPID
water if stationary. If travelling and empty cassette and then travelling some more, 1 to 1.5L cold
water and two heaped capfuls of home brand nappy treatment and detergent will self mix. Don't buy large container as goes off. Check use by date.
801996
Reply By: Krooznalong - Tuesday, Nov 12, 2013 at 14:13
What do the products containing Sodium Percarbonate actually do - mask odour or break down "stuff" or both?
521293
Steralise with oxygen. Not dissimilar to hydrogen peroxide in action.
801997
