Loctite on timing belt tensioner bearing bolt
Submitted: Tuesday, Nov 12, 2013 at 21:51
AaronBarrel
Hi guys, just finished changing my timing belt, tensioner bearing and hydraulic tensioner on my HZJ105 and am just wondering if anyone uses Loctite on the timing belt tensioner bearing bolt (Allen key bolt). I didn't as my
Gregory's manual didn't mention it but looking at a Toyota service manual it does. Thinking about taking back off and applying it for piece of mind but i haven't seen anyone mention it as a must do on any forums. Thoughts anyone???
Reply By: GrumpyOldFart - Tuesday, Nov 12, 2013 at 22:31
I locktite
mine.
Also change the
water pump every third belt change.
Dru
| Remember
Life is short, Break the rules, Forgive quickly, Kiss slowly, Love truly,
Laugh uncontrollably, And never regret anything that made you smileLifetime Member My Profile My Blog Send Message |
521331
Reply By: Bob Y. - Qld - Tuesday, Nov 12, 2013 at 22:36
AB,
If it's going to niggle at you. then I'd take it off and give it a hit with some 243. And if toyota mention it, then it might be safer to do it, eh.
Would make a real mess if that bolt came loose.........
Years ago we had a few drive shafts fall off, because the flange bolts worked loose. Started using 243 on them, and no more dramas.
Bob.
521332
Reply By: AaronBarrel - Wednesday, Nov 13, 2013 at 06:56
Righto, will Loctite it tonight.
No real drama, gives me something to do after work and then warrants a good job finished beer lol..
Thanks guys.
Aaron
521348
Reply By: TerraFirma - Wednesday, Nov 13, 2013 at 12:37
The
water pump replacement or check is good advice.
521361
Reply By: bluefella - Wednesday, Nov 13, 2013 at 18:54
G'day Grumpy
If it's torqued to the right specs I reckon should be okay, Loctite on the fan to
water pump housing for sure.
521378
Follow Up By: bluefella - Wednesday, Nov 13, 2013 at 18:56
Sorry should read G'day Aaron.
802060
Follow Up By: bluefella - Wednesday, Nov 13, 2013 at 19:06
I should add that the toque wrench is the most important tool in my tool box.
802061
Reply By: troopmaster96 - Wednesday, Nov 13, 2013 at 20:58
Howdy, just done my 1HZ for the fourth time, never used Loctite.
521390
Reply By: AaronBarrel - Thursday, Nov 14, 2013 at 12:22
Thanks guys. I did Loctite it in the end and tightened to spec with torque wrench. Prob would have been alright but I do like to do things by the book so I am happy now lol. Thanks again :)
521424
