1983 2.2 hilux diesel engine-- altenator in restored toyoace camper
Submitted: Thursday, Nov 14, 2013 at 18:31
ThreadID: 105126 Views:2086 Replies:1 FollowUps:1
am adjusting the fan belt tension, have taken the drivers seat out also the plate for access. looks as though will have to move aside the aircon pump to locate bolts for adjustment.
have notice 2 pipes at rear of altenator . question --what are they for
Reply By: Ross M - Thursday, Nov 14, 2013 at 18:51
One pipe is the vacuum hose from the brake booster which goes to the vacuum pump on the back of the alternator.
It has to be lubricated, so it will usually have an oil supply(small oil hose), to seal the vac pump as it works and the air the vac pump drags in will exit through a hose which attaches to the sump ie air and oil drain dumped into sump. Perfectly normal setup.
AnswerID: 521455
Follow Up By: keviny6 - Thursday, Nov 14, 2013 at 19:43
thank you for reply, before I went any further thought I would check
FollowupID: 802150
