transfer case bearing replacement
Submitted: Saturday, Feb 14, 2004 at 19:00
ThreadID: 10526 Views:1743 Replies:1 FollowUps:1
Hi all, Does anyone know if the front output bearing on an '88 sahara t/case can be removed without splitting the t/case from the 5 speed. You can see, touch and play with the bearing after removing the front drive shaft and pinion, but the bearing won,t come out (yes the circlip was removed). The new bearing seems to slip on and off up to the old one easily. Tried a slied hammer to no evail. Any suggestions.Thanks.
Reply By: Topcat (WA) - Saturday, Feb 14, 2004 at 20:58
Hi tour boy, unfortunately you will have to split the transfer front casing to remove the front output shaft (which is pressed into position) to get at the bearing. You will need to remove the output shaft & bearing & fit new bearing & output shaft with a suitable press & jig arrangement. Hope this helps. Cheers.Have Wheels Will Travel
AnswerID: 46715
Follow Up By: tour boy - Sunday, Feb 15, 2004 at 17:41
Thanks for that, I was hoping that I wouldn't have to.
FollowupID: 308777
