Dual Cab Racks rattling
Submitted: Monday, Dec 16, 2013 at 11:47
nat f
I purchased these racks several months ago. Does anyone know how I can stop the rattling in my hitch receiver.I have tried putting timber wedges but they need adjusting every now and then.
http://www.ebay.com.au/itm/hard-tonneau-racks-hard-tonneau-cover-ladder-racks-builders-racks-tradesman-rack-/151180746909?pt=AU_Car_Parts_Accessories&hash=item233313209d
Reply By: Ron N - Monday, Dec 16, 2013 at 11:58
Nat - I slipped thin, sheet-metal shims into
the gap, cut to size to match the sides of the RHS and drilled to allow them to be held in position by the retaining pin.
You need to grease them, or they'll jam the RHS in the receiver with dirt and rust after a few months without removal of the hitch.
Cheers, Ron.
523161
Reply By: Member - Rosss - Monday, Dec 16, 2013 at 12:40
Drill a hole in the bottom of the receiver, weld a nut over the hole and put a bolt into it and when the tongue is in do the bolt up tight onto the tongue.
523163
Follow Up By: Member Andys Adventures - Tuesday, Dec 17, 2013 at 07:54
Tritons come with that bolt as standard. Never had a problem with rattle.
804510
Reply By: Member - Rod N (QLD) - Monday, Dec 16, 2013 at 12:48
If you want to buy something look here
Anti-rattle devices
I made my own version of the sleeve type.
523164
Follow Up By: nat f - Monday, Dec 16, 2013 at 15:30
These anti rattle devices look like they will do the job.
804475
Reply By: Ross M - Monday, Dec 16, 2013 at 21:57
Near the front of the receiver drill a 6.5mm hole and top it 8mm. The wall thickness is sufficient and then use a short 8mm bolt tightened to eliminate the movement causing the rattle.
523186
