Wednesday, Jan 01, 2014 at 14:21
You'd better go back to school,
Ross M. Nigel has the ratio figured correctly.
At 3.1:1, the diff has been changed from the original, which would have probably been around 5.0:1 or 6.0:1 ratio.
Of course, we're working on a major lack of information here - such as whether Nigel has a single wheel or dual wheel Coaster, and what the tyre size is, and the all-up weight of the vehicle.
Regardless, as soon as you start playing with gear ratios, diffs, and overall gearing, you're looking at serious dollars - and you're also opening a can of worms.
A Holden 202 usually pulls best at 3000-3500RPM at highway speeds, and if it's pulling a lot of all-up weight, then gearing the engine to run slower will only reduce its pulling ability, and possibly do nothing to reduce
fuel consumption.
Bottom line is, if you have a rusty old bus, that's done a lot of k's, been repowered, and has seen better days, you're better off to put the money you're going to spend on altering gearing, towards another bus in better condition.
More than one quite good-looking vehicle has been seen riding on a tilt-tray down to Sims, because the repairs or modifications required are more than the vehicle is worth.
Age is what catches up with all of us - and it catches up with vehicles much faster than humans.
If you plan on spending serious money on anything over 15 yrs old, it had better be a classic, and in good condition, otherwise you're throwing money down the drain.
Older vehicles become a nightmare to try and find parts for, and no-one wants anything to do with them.
If you have a vehicle from the 1970's and 1980's, the only buyers you'll find when you want to quit it, are those with a nostalgic bent.
805281
